Saving Gas
Old Aug 21, 2003 | 02:57 PM
CivHatchH22's Avatar
Default Saving Gas
I have a 92 Civic hatch with a h22 swap... some people tell me to use premium and others regular gas... What be the difference between the two for my engine? Could i use regular to save gas money and not screw anything up? Also i drive a 99 ford f250, people say turning Overdrive off saves gas... that true?
Old Aug 21, 2003 | 03:11 PM
User 5426's Avatar
I use premium on my h22a eg just to don't screw up anything. Turning off Overdrive is a sure way to burn more gas. One of overdrive's main reason is to save gas.
Old Aug 21, 2003 | 03:12 PM
Default Re: (SeaQuake)
what would regular do to my engine? anything?
Old Aug 21, 2003 | 03:55 PM
TeStUdO's Avatar
Default Re: (CivHatchH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivHatchH22 &raquo;</TD></TR><TR><TD CLASS="quote">what would regular do to my engine? anything?</TD></TR></TABLE>
it just doesnt burn as cleanly, i get better gas mileage with premium. i can tell the difference in my car with 91 or 92 octane. of course my car is turbo though
Old Aug 21, 2003 | 05:49 PM
Eyewitness's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
it just doesnt burn as cleanly, i get better gas mileage with premium. i can tell the difference in my car with 91 or 92 octane. of course my car is turbo though</TD></TR></TABLE>
Unless your car is relativily built....anything higher than 87 will not yield you a noticable difference...its called the placebo effect. almost all usdm moters are designed to effiecently burn 87....they will note if they require a higher octane to be used..but then again ..your turboed so you prolly have some goodies
Old Aug 21, 2003 | 06:53 PM
TeStUdO's Avatar
Default Re: (Eyewitness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyewitness &raquo;</TD></TR><TR><TD CLASS="quote">
your turboed so you prolly have some goodies</TD></TR></TABLE>
1 or 2 , but i bet if you compared tanks you would get better gas mileage out of 92 than you would 87
Old Aug 21, 2003 | 07:12 PM
Mohudsolo's Avatar
All the GSRs I've seen or heard of being checked came from the factory with the timing retarded 2 degrees from the recommended setting. The assumption was Honda making sure people who put in 87 would not hurt the motor. With the timing at spec or advanced 2-3 degrees, there is much more midrange power. Probably Honda did the same with the Preludes. My bet is the H22 can run 87 with the timing retarded a few degrees and give up some power and milage. Why swap in the bigger motor then give up some of the power? Do you still have the factory knock sensors? If there you will give up some power but be OK. If not hooked up, run the 92
Old Aug 21, 2003 | 07:40 PM
CD8's Avatar
CD8
Unless your car is relativily built....anything higher than 87 will not yield you a noticable difference...its called the placebo effect. almost all usdm moters are designed to effiecently burn 87....they will note if they require a higher octane to be used..but then again ..your turboed so you prolly have some goodies</TD></TR></TABLE>right, but his motor is a JDM h22a. i dont burn anything less than 91 in mine
Old Aug 21, 2003 | 08:27 PM
User 5426's Avatar
Default Re: (CD8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">right, but his motor is a JDM h22a. i dont burn anything less than 91 in mine </TD></TR></TABLE>
Yep, it's bad enough that most of california has only 91 octane but I will run what I got.
Old Aug 21, 2003 | 10:40 PM
CD8's Avatar
CD8
word, AZ is in the same crapshoot as you as far as gas is concerned.
djdownfawl
Honda Civic (2001 - 2005)
13
Mar 23, 2008 07:57 PM
Unit44justin
13
Oct 4, 2005 12:54 PM
94civicEX
Aug 18, 2005 05:35 AM
TurboTagTeam
Oct 4, 2004 05:57 PM
Darkane
Aug 3, 2004 12:44 PM
