Gain pounds by moving wastegate line
Old Aug 21, 2003 | 10:14 AM
ScottEK's Avatar
Default Gain pounds by moving wastegate line
I remember reading a thread on either this message board or the http://www.homemadeturbo.com board about gaining a few more pounds by moving the wastegate line. The idea behind it was that if you connect the wastegate to the compressor outlet you are reading the pressure before you go through the intercooler and get pressure drop. Where is a good location to T into for the wastegate that is after the intercooler?
Old Aug 21, 2003 | 10:18 AM
lazerus's Avatar
Default Re: Gain pounds by moving wastegate line (beta13)
i always use behind the TB for an accurate pressure source of what the engine is seeing.
Old Aug 21, 2003 | 10:30 AM
ScottEK's Avatar
Default Re: Gain pounds by moving wastegate line (lazerus)
Any pics, two concerns...
1. I'm already T'ing between the FPR and the IM for my BOV.
2. I need a larger size port because the wastegate uses a larger vacuum line than the standard connections.
Old Aug 21, 2003 | 11:35 AM
rioninja's Avatar
The downfall to using the intake manifold as the source for your wastegate,
is that if you had a boost leak you would never know it. Think about that before you do it. If you really want to raise the boost, you can make a simple ball & spring boost controller for under $15.
Old Aug 21, 2003 | 12:01 PM
ScottEK's Avatar
Default Re: Gain pounds by moving wastegate line (rioninja)
I've made a ball and spring one, tapped it and did everything correctly but I'm scared to use it. Instead of just one line you now have two and a ball and spring, it just doesn't seem very dependable.
Old Aug 21, 2003 | 12:53 PM
ScottEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">The downfall to using the intake manifold as the source for your wastegate,
I don't get why you wouldn't know you had a boost leak?
Old Aug 21, 2003 | 05:54 PM
ScottEK's Avatar
Bump... Still looking to gain about 1.5-2 pounds of boost.
Old Aug 21, 2003 | 06:47 PM
InTeGrA B18b1's Avatar
boost controller thats about the only good way to raise boost
chriskey0829
Feb 1, 2006 07:10 PM
MooreBoost
Sep 7, 2004 07:22 AM
jwcardy
Sep 5, 2004 02:06 PM
2muchPSI
Nov 22, 2003 02:34 PM
phase12gsr
Oct 28, 2002 08:00 PM
