For FYI, How can you tell if you have a bent valve?
Old Aug 14, 2001 | 12:44 AM
Type R 98-0352's Avatar
Default For FYI, How can you tell if you have a bent valve?
Still a first year with a stick, let alone Type R. So how can you tell if you have a bent valve? Just shifted from 5th to 3rd for the first time at 80mph while meeting up with another ITR in Houston (Adam? Black ITR wherever you are???). Is that safe? Hit about 9,000 rpms.
Old Aug 14, 2001 | 12:54 AM
pho king guy's Avatar
Default Re: For FYI, How can you tell if you have a bent valve? (IntegraTypeR98)
you can REALLY tell if u have a bent valve, idles low, hard to start, u can tell... shifting from 5th to 3rd at 80 isn't bad, but that shouldn't put u at 9000 rpm... even so, did u hit the rev limiter? i've hit my rev limiter like 3 times, all by accident, just as long as u don't constantly go past redline... type-rs are made to handle that, just don't abuse it
Old Aug 14, 2001 | 01:01 AM
Type Goch's Avatar
New User
Default Re: For FYI, How can you tell if you have a bent valve? (gan ni nia)
9k isnt too bad on the stock Tach...also when you Downshift..revlimiter doesnt work.
Old Aug 14, 2001 | 01:30 AM
Default Re: For FYI, How can you tell if you have a bent valve? (Type Goch)
oh yeah duh
Old Aug 14, 2001 | 01:32 AM
MiraiZ's Avatar
my RL is at 9500....no probs!!
Old Aug 14, 2001 | 01:40 AM
RagingAngel's Avatar
If it is bad enough OBDII will tell you like mine did finally after 2years of constant banging on it....
You'll have to do a leakdown test if you suspect anything....
Old Aug 14, 2001 | 12:36 PM
PMTypeR's Avatar
Default Re: For FYI, How can you tell if you have a bent valve? (RagingAngel)
You'll most likely get a check engine light.. It will be a code that says misfiring on one of the cylinders. You'll keep getting this....
I unfortuanelty know this from experience. i had 2 bent valves fixed this spring...
Old Aug 14, 2001 | 12:49 PM
98TypeR's Avatar
Default Re: For FYI, How can you tell if you have a bent valve? (PMTypeR)
do a compression test. that will tell. you should be around 190-220 psi.
Old Aug 14, 2001 | 01:26 PM
norice's Avatar
Default Re: For FYI, How can you tell if you have a bent valve? (98TypeR)
If the tach indicated 9000rpm, you were probably at ~8700 rpm. Nothing to worry about I would guess.
Old Aug 14, 2001 | 02:42 PM
Warren's Avatar
Wrong-Way Wang
Default Re: For FYI, How can you tell if you have a bent valve? (norice)
When it sounds like a diesel engine, you know it's screwed.
Warren
Old Aug 15, 2001 | 02:17 AM
COREY ITR#625's Avatar
Default Re: For FYI, How can you tell if you have a bent valve? (George Knighton)
Correct me if I am wrong, but can't we get about 90-92 mph in 3rd gear. If you went to 3rd from 5th doing 80 mph, my guess is that you hit about 8100 rpms or a little higher. I wouldn't worry about it unless your car is idleing funny and your having a really hard time trying to get it started. I bent some valves in my car a couple of months ago and it was almost impossible to keep it started at low rpm's. I had to drive my car home because Acura didn't send a flat bed to get me (long story). My car seemed fine at highway speeds, but when I was getting off of my exit my car died and I lost the steering and brakes and almost hit the curb. The dealer told me that each cylinder is suppose to have 180 in each one. I'm sure your car is fine.
patrick_yi_82
May 14, 2010 08:30 PM
gmboogy
Sep 4, 2006 07:59 PM
pwr2lbs
Jun 1, 2005 07:05 PM
ALLMOTR_R
Oct 27, 2003 09:38 AM
Trac226
Jul 1, 2002 07:28 AM
