wuts the diff between theses engines
is there a difference between a jdm gsr engine and a gsr engine from canada.....if so wut is it?r they still both stamped with b18c1?
[Modified by trborex, 2:07 AM 8/14/2001]
Canadian = USDM specs
JDM has a higher compression 10.6:1 vs 10:1(for usdm and can)
higher power output 178hp (180ps) vs 170hp
tranny on a JDM b18c came with optional LSD
some JDM also came with auto tranny, meaning weak cams and ecu thats sort of unchipable (uses OBDII specs eprom)
also JDM ecu is much weaker in its prgram then USDM/can. one
