My RPM odometer is going haywire....need help!!!
My RPM odometer is going haywire. When I am cruising or punching it past 4000 RPM the RPM needle jumps forward uncontrollably. Although this has no effect on the performace....I am still paranoid that I am messing something up.
This problem happened to me before & I found out it was a loose ground wire. Tighten it and everything worked fine. NOw it is happening again.....and I can't figure out why.
Any suggestions? Bad gauge cluster?
might be a bad cluster, see if someone will let you use theirs to see if it works fine...btw, its called a tachometer.
quant
Oct 11, 2008 03:19 AM
SHG_EasyE
May 5, 2007 05:35 PM
b20vtech
Jan 12, 2006 04:50 PM
