antenna help
Old Aug 20, 2003 | 01:04 PM
beaterman's Avatar
Default antenna help
my antenna is stuck in the up position. i can still hear the motor running but nothing will happen. can somone help me with this minor problem. thanks
Old Aug 20, 2003 | 01:42 PM
timmy8151's Avatar
Default Re: antenna help (beaterman)
Sounds like the plastic chord of your antenna mast is broken. Just get a replacement mast from eBay for $25 and change out the masts.
Old Aug 20, 2003 | 03:12 PM
Rpc07's Avatar
Default Re: antenna help (timmy8151)
that happened to me and i just pushed the antenna down halfway so it looks a lot better now and i took the motor out so it jsut stays there and it looks good and i get great reception still.
Old Aug 20, 2003 | 03:56 PM
beaterman's Avatar
Default Re: antenna help (Rpc07)
well i cant push my antenna down. i could careless about it working. i dont even listen to the radio most of the time its my cd's and the rest of the time i just listen to my car. so can i just open up where my antenna comes down and pull it down and take the motor out?
Old Aug 20, 2003 | 04:26 PM
timmy8151's Avatar
If you don't listen to the antenna much, you could just do a S2K antenna conversion. To remove the motor, you just need to open up the trunk lining and remove it.
Old Aug 20, 2003 | 05:50 PM
typeR#0427's Avatar
Mine did the same. I found it to be a nice excuse to buy a S2000 antenna. There are kits and such ranging from $16-$90.
I bought the whole thing with amplifier from Honda for $90.00
Spectrum24x
Jun 16, 2006 08:40 AM
debogsr
Jun 3, 2004 10:30 AM
SleepinGSR
Feb 27, 2002 02:03 PM
99ITR_SC
Sep 24, 2001 11:18 AM
