Fuel Cut only at 6800 rpm!?!
Old Aug 20, 2003 | 02:35 PM
Audrius Z's Avatar
Default Fuel Cut only at 6800 rpm!?!
What could be wrong? On D16A9 Fuel cut should be at 7600 rpm, what makes it drop to 6800? Sparks? Sensors? Etc? Only cold air intake is done so far...
Old Aug 20, 2003 | 02:52 PM
Stupid Ass's Avatar
Default Re: Fuel Cut only at 6800 rpm!?! (Audrius Z)
What ECU? It doesnt make much power past 6800 anyways... I wouldn't go past 7200...
Old Aug 20, 2003 | 03:31 PM
91civicEX's Avatar
your tach could be lagging behind
is it aftermarket or stock?
Old Aug 20, 2003 | 03:32 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
tach lag....never heard of that...but keep me posted on this one....
Old Aug 20, 2003 | 09:16 PM
XrcR6's Avatar
Cold vs Warm/Hot rpm limit? Stock ECU's on the US cars have them as a safety measure, I imagine all OEM Honda ECU's encorporate something similar. For example, PM6 (90-91 D16A6) was something like 6800/7200 I believe. Not sure what exact variables (water temp, oil pressure, etc.) it looks at to determine when its good to go.
But if you're testing this right after or fairly close to just starting up, you should warm it up more.
Old Aug 21, 2003 | 12:45 AM
Audrius Z's Avatar
Default Re: Fuel Cut only at 6800 rpm!?! (XrcR6)
I never rew up more than ~3000 rpm while cold! 6800 was on a warm engine. Today am gonna change sparks and fuel filter to new ones and if problem remains - gonna look for temperature sensor.. Thanks for Your replies
[QUOTE=XrcR6]Cold vs Warm/Hot rpm limit? Stock ECU's on the US cars have them as a safety measure, I imagine all OEM Honda ECU's encorporate something similar. For example, PM6 (90-91 D16A6) was something like 6800/7200 I believe. Not sure what exact variables (water temp, oil pressure, etc.) it looks at to determine when its good to go.
Old Aug 21, 2003 | 07:58 AM
slooogsr's Avatar
my bet is on the ecu............ again which one are u running??
Old Aug 23, 2003 | 01:55 PM
Audrius Z's Avatar
Default Re: (sloorex)
Today I finally tested my new Spoon chiptuned ECU! Was afraid to rew up more than ~8000rpm Iddle raised from ~750 to ~1000rpm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex &raquo;</TD></TR><TR><TD CLASS="quote">my bet is on the ecu............ again which one are u running??</TD></TR></TABLE>
Old Aug 23, 2003 | 03:43 PM
nevin's Avatar
tach lag y0! not to be confused with tire bog :/
joe.wong321
30
Dec 8, 2007 02:23 AM
IA95civicDX
13
Oct 25, 2005 05:10 PM
89civichatchback
21
Jan 28, 2003 05:20 PM
EleanoR
Oct 10, 2002 01:49 PM
Tommy_Gunns
Jul 28, 2002 03:11 PM
