Injector Wiring already searched
Old Aug 19, 2003 | 07:11 PM
stinker504's Avatar
Default Injector Wiring already searched
Okay guys I have to hook up a resistor box to use my RX-7 460cc injectors. Here is the problem. On my factory injector clips the yellow/black wires are all on the right side of the clip. But, on the rx-7 clips the yellow/black wires are all on the left side of the clips. Should I hook up the resistor wires to the left or right side of the rx-7 clip?
Old Aug 19, 2003 | 09:38 PM
Blown90hatcH's Avatar
Default Re: Injector Wiring already searched (stinker504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinker504 &raquo;</TD></TR><TR><TD CLASS="quote">Okay guys I have to hook up a resistor box to use my RX-7 460cc injectors. Here is the problem. On my factory injector clips the yellow/black wires are all on the right side of the clip. But, on the rx-7 clips the yellow/black wires are all on the left side of the clips. Should I hook up the resistor wires to the left or right side of the rx-7 clip?</TD></TR></TABLE>
I ran mine so that they matched what the resistor box normally saw.
Old Aug 20, 2003 | 07:44 AM
stinker504's Avatar
Thanks. So when I cut the old clips and put the new clips on I guess I'll just match up the colors. If any one disagrees please stop me now
Old Aug 20, 2003 | 07:50 AM
VTC_CiViC's Avatar
Are you SURE your injectors require a resistor box? I have a set of 2G RX7 460's and they're high impedence (no resistor).
Old Aug 20, 2003 | 11:35 AM
stinker504's Avatar
I'm sure I measured them to be 2.6ohms. Or was it 3.6ohms either way it was low.
markgo
Nov 8, 2006 11:39 AM
Dunc
Oct 2, 2005 02:12 PM
ironcheftony
Apr 14, 2005 02:39 PM
Zeus
May 30, 2003 03:07 PM
