is it possible to install ITR rear sway bar.. backwards??
Old Aug 19, 2003 | 05:10 PM
mingchi69's Avatar
I to Smooch Pickle
Default is it possible to install ITR rear sway bar.. backwards??
is it?? on my car. everything bolts.. it just.. seems funny, maybe just me
Old Aug 19, 2003 | 05:22 PM
EL Vap133's Avatar
Default Re: is it possible to install ITR rear sway bar.. backwards?? (mingchi69)
Backwards??? There is no way....
Old Aug 19, 2003 | 05:35 PM
One Bad GeeSeeR's Avatar
maybe your thinking upside down.
Carlo
Old Aug 19, 2003 | 05:37 PM
Boges's Avatar
Default Re: is it possible to install ITR rear sway bar.. backwards?? (Vap133)
It could easily be upside down. Mine was when i bought my car.
Old Aug 19, 2003 | 05:46 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: is it possible to install ITR rear sway bar.. backwards?? (Boges)
nah.. its impossible.. i just imagined it..
but just to make sure.. after the long bar that goes across the chassis, does the bar bend toward the lca, then loops over the lca right?? because that's how mine is.. and the endlink is never at 90 degrees.. but to be ok. o well
Old Aug 19, 2003 | 05:50 PM
thaiphob's Avatar
Nikon!!!
just take a pic of your stock one or remember how it looks before you install it.
Old Aug 19, 2003 | 05:53 PM
mingchi69's Avatar
I to Smooch Pickle
Default Re: is it possible to install ITR rear sway bar.. backwards?? (thaiphob)
i gave it away to somebody already.. too late
https://honda-tech.com/zerothread?id=291990
.. like on those pictures.. does the bar seem to be bending towards the LCA, then goes over the LCA?? it does doesnt it?? because that's how mine is.. but the bracket is never at 90 degrees, maybe like 70 degrees or so.. seems ok though, but just want to make sure
Old Aug 19, 2003 | 08:53 PM
The-LS's Avatar
I beleive a few people have mistakenly installed the bar on backwards before. Everything should bolt up fine too.
Old Aug 19, 2003 | 10:49 PM
nospeedlimit143's Avatar
Default Re: is it possible to install ITR rear sway bar.. backwards?? (Black-LS)
backwards.... umm... not unless they really tried...
... upside down... definite possibility. make sure the arms bend up and over the LCA's.
Old Aug 19, 2003 | 11:44 PM
RedLinin247
Guest
Posts: n/a
Default Re: is it possible to install ITR rear sway bar.. backwards?? (nospeedlimit143)
lots of people have put them in upside down that i have seen. but never backwards.
Old Aug 20, 2003 | 06:49 AM
IntEGNYC's Avatar
Default Re: is it possible to install ITR rear sway bar.. backwards?? (RedLinin247)
how about reversed or flipped?
Old Aug 20, 2003 | 08:28 AM
zad5's Avatar
it is possible trust me. i have seen a picture before. here ill try to look for the picture.
edit. well i couldn't find one but trust me ive seen it before. ask bsq he is a member here.
PARADOX_sf
Suspension & Brakes
Jan 24, 2007 05:40 AM
Therapy
Jan 6, 2004 07:51 PM
One Bad GeeSeeR
May 6, 2003 04:46 PM
Driven
Mar 27, 2003 08:25 AM
swarsing
Nov 9, 2001 07:22 AM
