Pulling a Gas Tank
I was wondering if it were to be easy to pull one out, too lazy right now to go check the haymes manual and i'm at work. My gas tank i believe is leaking at the seems so i'm putting gas only in half way so i might be able to get a hold of one. so just wondering how hard it would be. thanks guys.
its not hard but a very shitty and dirty job. run the tank as dry as you can before removing the tank. you'll thank yourself later.
and make sure to work in a very ventilated area. outside is usually a good spot, but make sure no one is smoking.
cool
now. are all the bolts easy to get to n' stuff.
i can see the 2 pieces holding the tank up, so i'm assuming i get rid of the straps and htan work from tehre
From: I told you to wait in the truck in Texas, United States
Nice thing about a Honda is they put a drain plug on the tank..
It is a 17mm on the drivers side,rear of tank.
the straps are pretty easy to get off (well they were for my case). remember that you need to remove 2-3 rubber hoses and one feed line. i think the feed line has a 14mm connection bolt that was a bitch for me to get off!
87X
Oct 20, 2003 05:17 PM
