I'm retarded, which way is advanced?
engine spins counter-clockwise sooooo.....turning cam gear away from the firewall, counter-CW, makes the valves open sooner = advanced?
is that right? I am literally retarded about this. somebody help me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller »</TD></TR><TR><TD CLASS="quote">engine spins counter-clockwise sooooo.....turning cam gear away from the firewall, counter-CW, makes the valves open sooner = advanced?</TD></TR></TABLE>Turn the camSHAFT counterclockwise is advanced. Doesn't matter how you do this... If you leave the sprocket attached & skip a tooth, counterclockwise, that's advanced.
If you use adjustable sprockets, think about it this way: Hold the sprocket & rotate the camSHAFT counterclockwise. That way it doesn't sound like it's backwards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Turn the camSHAFT counterclockwise is advanced. Doesn't matter how you do this... If you leave the sprocket attached & skip a tooth, counterclockwise, that's advanced.
I see said the blind man
that makes sense now.
pureplayaz
21
Nov 16, 2008 02:11 PM
