funny idle?
Old Aug 18, 2003 | 11:22 PM
doh boy's Avatar
Default funny idle?
my car idles normal, but when i push on the brake while its at idle it'll jump from 6-700 to 1200 and drop down to 3-400 and then go back to normal (6-700). is this something bad?
*edit* this happens whether the engine is cold or hot..
Old Aug 19, 2003 | 08:50 AM
EL Vap133's Avatar
Default Re: funny idle? (doh boy)
kinda sounds like a vacuum problem, all your hoses connected where they should be?
Old Aug 19, 2003 | 09:19 AM
Vinceg99's Avatar
Default Re: funny idle? (Vap133)
Could be possibly a leaky brake booster also but like he said above would be a vacuum leak....
Old Aug 19, 2003 | 09:23 AM
jmac's Avatar
could be the idle air controller...
does that car idle high when it first starts up?
Old Aug 19, 2003 | 09:34 AM
Vinceg99's Avatar
Default Re: funny idle? (jmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmac &raquo;</TD></TR><TR><TD CLASS="quote">could be the idle air controller...
does that car idle high when it first starts up?</TD></TR></TABLE>
I dont think its the IACV it only happens when he pushes the brakes down when my IACV was bad it did it no matter what but to check it just umplug your IACV and see if it still happens if it does its not the IACV if it doesnt then it is the IACV or well otherwise known as the EACV.
Zee.I
Jul 11, 2021 11:36 PM
KidDxbOrI
Jan 14, 2014 04:29 PM
`chrisb
May 4, 2008 01:46 PM
TurboSI24
Nov 23, 2005 03:39 PM
SI-vtec92
May 10, 2005 03:25 AM
