Vouch for EXEDY clutches?
Old Aug 18, 2003 | 06:37 PM
ScottFern's Avatar
Default Vouch for EXEDY clutches?
I just ordered one for my 95 gsr engine. I was told they make clutches for honda and some aftermarket companies too.
Just curious what people had to say about them ?? Thanks in advance
Old Aug 18, 2003 | 06:51 PM
mmuller's Avatar
Mad Scientist
Default Re: Vouch for EXEDY clutches? (ScottFern)
i put mine 2000 miles ago and the release bearing is already bad....
Old Aug 18, 2003 | 06:56 PM
ScottFern's Avatar
Default Re: Vouch for EXEDY clutches? (mmuller)
oh boy, this isn't good....
Old Aug 18, 2003 | 06:57 PM
machine4321's Avatar
about 4000 km and mine has squeeld since day one ....other than that it grabs good ....
Old Aug 18, 2003 | 07:08 PM
ScottFern's Avatar
Default Re: (machine4321)
I don't understand, i was told they make clutches for a lot of japanese cars, and they make clutches for honda/acura?
Old Aug 18, 2003 | 07:24 PM
Weston's Avatar
You can already vouch for Exedy's quality... your stock clutch is made by Exedy. That was even confirmed by my friend who handles the performance parts division of my local Acura dealer.
Don't take one person's bad experience and automatically assume all of their stuff is crap. There are many things that could have happened that isn't Exedy's fault. Maybe the install was done poorly or some original parts were reused when they were supposed to be replaced. Some of the so called "speed shops" around here have been known to rip people off by using old parts, then keeping the new stuff that comes in the kit for themselves.
I know at least one person who's had great results from the Exedy organic racing clutch for the past year that he's had it. I've even raced in his car and there's no indication of anything wrong with it.
I just bought one this afternoon, and I don't expect any problems, based on the good reputation that Exedy has, and the experiences of myself and people that I know.
Old Aug 18, 2003 | 07:29 PM
yes i think its a good clutch ..mine just a upgraded stock basicly...and yes i pulled a stock exedy out of my jdm motor....i think the ludes have some probs but other than that ..i like it
Old Aug 18, 2003 | 07:47 PM
Volcom's Avatar
I've got an Exedy clutch and I've had no problems with it in 10K miles. I am running a stock B18B1 with a 12.5 pound flywheel. If you are running higher than normal HP, then get something stronger. If you're stock or stock plus I/H/E, flywheel, stuff like that, you'll be fine as long as it was put in correctly.
Old Aug 18, 2003 | 09:50 PM
roydogg's Avatar
Default Re: (Volcom)
Mines is holding up pretty good for the last year and a half. It can definately take a beating though and lots of it.
Old Aug 18, 2003 | 10:57 PM
igotyofire's Avatar
Default Re: (roydogg)
yea its a bomb *** clutch, i think mine is slipping or needs some adjusting, but i definatly love it , plan for my next clutch to be an exedy also, right now i have the organic i wanna get the cermitalic next i think, but i have about 20k on mine it grips nice i just think it needs some adjusting, if not then it is slipping but its taken alot of abuse , specially since i tuaght two idiots how to drive stick and they burnt my clutch all day long
Exedy two
Old Aug 18, 2003 | 11:02 PM
9redsi9's Avatar
Mines got ~10K on it, not one problem not one complaint.
Old Aug 19, 2003 | 04:04 AM
Jeff C's Avatar
Which one are you planning on getting?
I had the Organic (OEM replacement) on my b20vtec. I put about 19k on it before the disc cracked. Its a good stock replacement. It has good pedal feel and good clamping. If you are planning on doing a bit of drag racing of planning on some hefty mods, then I would not get the Organic one.
My thread
Old Aug 19, 2003 | 09:01 AM
PupaScoopa's Avatar
Default Re: Vouch for EXEDY clutches? (Jeff C)
I'm happy with the organic disc. The engagement/release is much smoother than the stock clutch was.
Old Aug 19, 2003 | 09:08 AM
4DeepCivic's Avatar
My exedy is holding up. It's a little more stiffer than stock and grabs well. It's consistent and I know that all the parts are brand new. The bearing I got with my Exedy kit is the same as the one that's sold at Honda and Acura dealerships. Some other clutch makers are use remanufactured diaphrams.
Old Aug 19, 2003 | 01:29 PM
Weston's Avatar
I put mine in last night, along with a 9.7 lb flywheel. It's pretty nice. It obviously grips pretty good, but you can be pretty smooth with it after only a small amount of getting used to it.
Old Aug 19, 2003 | 03:45 PM
ScottFern's Avatar
Default Re: (Weston)
cool, phew, sounds like i did ok then. Mine is the stock replacement clutch. Its the organic one too.
I am running b18c1 I/H/E, w/ stage 2 cams and skunk2 intake mani.....I think it should hold up nicely
thanks guys
Old Aug 19, 2003 | 04:39 PM
igotyofire's Avatar
Default Re: (ScottFern)
anyone have the cerametalic one?
Old Aug 19, 2003 | 07:54 PM
GeeReg's Avatar
Default Re: (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">anyone have the cerametalic one?</TD></TR></TABLE>
I do. It's definatly overkill for my setup (bolt-ons and recently Toda A's), but I haven't had any problems with it. With my 7 lb Clutchmasters FW, it takes some getting used to..tends to shudder if you don't give it enough gas when taking off. It also doesn't seem to like being slipped to much, makes an interesting noise. I really can't say anything bad about it though. I have about 10k on it.
Old Aug 19, 2003 | 07:59 PM
MrTodd's Avatar
Default Re: (GeeReg)
So is the organic exedy OEM style any stronger/grippier than and actual OEM clutch?
Old Aug 19, 2003 | 09:19 PM
VAAJ's Avatar
Default Re: (MrTodd)
I have this kit with the organic disc. This clutch is alot smoother then the OEM plus it grabs much better. The clutch makes a weird noise when first install, but after the break in it was dead silent.
Old Aug 19, 2003 | 09:41 PM
roydogg's Avatar
Default Re: (drift2live)
This is how my exedy clutch looks after about 2 years of beating.
Old Aug 19, 2003 | 11:02 PM
leadfoot78's Avatar
all good here i dont know how many miles is on it though, maybe 2000mi. I like it way way more than the ACT 6puck.
Old Aug 19, 2003 | 11:33 PM
Stripped Honda's Avatar
99-0104
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">This is how my exedy clutch looks after about 2 years of beating.
what was the use of that pict we cant even see what the disc looks like
my experances are very good with exidy clutches never had a bad one i have installed over 100 of them ..... just make sure it comes with a made in japan bearing .. some of the companys put a cheap one in to make more money ... i try to stick with a koyo bearing and have very few problems with them
Old Aug 19, 2003 | 11:45 PM
roydogg's Avatar
Default Re: (Stripped Honda)
Sorry I had to leave to work before the tech took the plate off. But he said that the disk is still good and the plate had no glazing or bent teeth.
Old Aug 20, 2003 | 01:33 AM
Casey's Avatar
ive had both(organic and cerametallic) organic was full face, smooth engagement, easy to drive. cerametallic was pretty hardcore. Hard *** engagement, it was 3 puck i believe, and definitly did not liked to be slipped. It was on or off
