100LL gas/fuel okay to use?
Since I can't find premium gas around here in AZ, I found out one of the airports sells what they call "100LL" for $2.35 a gallon. Is that okay to use?
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 »</TD></TR><TR><TD CLASS="quote">Yeah, well I can get unleaded low octane, but that is crap and I have to wait in line for 1+ hours.</TD></TR></TABLE>
did you notice on your gauge cluster it says unleaded premium fuel only?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">
theres currently a gas supply shortage in Az. Most gas stations if they are even open, only have 87 or 89 available.
Onyx, I plan on buying 87 or 89 which ever is available and putting in octane booster. Not ideal, but there really is no alternative for now. Most stations ran out of 91 on saturday.
</TD></TR></TABLE>theres currently a gas supply shortage in Az. Most gas stations if they are even open, only have 87 or 89 available.
then take 89...even 87 should be fine. your knock sensor will go very happy and your timing will be retarded, but
just dont go rpm happy on the car, and octane booster = crap. you'd literally need like 5 gallons of it to make a difference from 87.
imho i wouldnt drive if i didnt need to.
what happened to AZ that theres a fuel short?
Pipeline broke, takes 2 weeks to fix.
So no one thinks Low Lead 100 octane is okay? Mustang guys in AZ seemed to think it was okay.
if you dont have a cat or are not worry about your o2 sensor , then you can run leaded fuel , like c-12 which is equal to 110 octane
</TD></TR></TABLE>if you dont have a cat or are not worry about your o2 sensor , then you can run leaded fuel , like c-12 which is equal to 110 octane
Don't put 100LL in your car, and don't put unleaded premium gasoline in your airplane.
https://honda-tech.com/zerothread?id=595672
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">then take 89...even 87 should be fine. your knock sensor will go very happy and your timing will be retarded, but
just dont go rpm happy on the car, </TD></TR></TABLE>
I believe the knock sensor stops working around 5k, so like soup **** said, dont redline your car, or your motor wont pull back your timing and you might hear some knock knock in your motor.
hehe, awesome, that was what I wanted to hear, someone who tried it
Alright, guess I am getting up at 3 a.m. to get gas. Better get some rest, night all.
From: Formerly WI, now back in NorCal and everywhere else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">
Don't put 100LL in your car, and don't put unleaded premium gasoline in your airplane.</TD></TR></TABLE>
As a pilot, I'll second this one. No you cannot use 100 Low Lead in a car that requires unleaded gas. There's lots of things this will screw up as the others have mentioned.
do you not understand why there is lead in LL gasoline? the lead is in a liquid state and is used to lubricate the brass valve guides in heads that do not have hardened valve guides and seats. if you put a LL gas into your car, the lead will clog injectors, build up aroune the valve seats, toast the cat, kill the O2 sensors, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx00 »</TD></TR><TR><TD CLASS="quote">Pipeline broke, takes 2 weeks to fix.
So no one thinks Low Lead 100 octane is okay? Mustang guys in AZ seemed to think it was okay.</TD></TR></TABLE>
i run it, its great stuff, i just hope you don't have a cat...
we used 100-octane LL durring a race event drove the car 120 miles to the event
on 93octane car drove perfect crvtec setup with je 12-5-1 compression piston
about a mile from the track the gas light came so we filled it up with 3-gallons of 100-octane-LL fisrt run halfway down the track the car frickin misfired like mother!!! never had this happend ran consitant 12.4's all day with 100-oct UL
allmotor i will never!! use the 100-LL again period.
just some advise for you to think about its not worth it...
Rikaro
Aug 31, 2007 04:44 PM
Fook_me_honda
10
Jun 26, 2007 06:57 PM
