suspension problem
Old Aug 18, 2003 | 10:26 AM
wb1.6's Avatar
Default suspension problem
i posted this in the other honda/acura vehicules section but no one replied
since i bought my tokico hp shocks and G-force coilover, i have been noticing a clinging noise when im on uneven roads. it bugs me and i cant get rid of it.
i have 1.6 EL
Old Aug 18, 2003 | 11:22 AM
DsITR's Avatar
Default Re: suspension problem (wb1.6)
did you install the coilovers correctly?
for example w/my Ground Controls there is a rubber slab that you wrap around the shock, it goes in btwn the threaded body and the shock to accomidate for the difference in diameter, it is there to keep the threaded body from shifting, and claning against the shock...that may be what the clanging noise is.
Old Aug 19, 2003 | 06:29 AM
wb1.6's Avatar
Default Re: suspension problem (DsR)
no i did install the rubber rings around the shocks.
it sounds more like its comming from the top plate of the coil
Old Aug 19, 2003 | 07:09 AM
Doctor CorteZ's Avatar
turn the spring untill it feels like its sitting solid on the perch.
toshko321
49
Sep 8, 2009 04:47 PM
thriller
Suspension & Brakes
Aug 28, 2005 06:43 AM
vandeec5
Mar 15, 2004 09:52 AM
ZensokuEK
Mar 19, 2003 05:10 PM
