b20 vtec timong belt and tensioner
Old Aug 18, 2003 | 07:34 AM
94turbolude's Avatar
Default b20 vtec timong belt and tensioner
well i need to know what timing belt and tensin er to get for a friends enging.
The combo is a 97' b20 block, with a b16 head. I am using the type r water and oil pump and can not get a b16 belt to fit. What am i doing wrong?
Blake
Old Aug 18, 2003 | 08:59 AM
ttt
Old Aug 18, 2003 | 09:11 AM
Benny Hinn's Avatar
Default Re: (94turbolude)
Can't use a B16 belt.
You need a GSR or Type R belt.
Old Aug 18, 2003 | 12:47 PM
jcda6's Avatar
Default Re: b20 vtec timong belt and tensioner (94turbolude)
What ever oil pump you use dictates which belt you will need. In your case, since you're using the ITR oil pump, you will need to purchase the GSR/ITR timing belt from now on.
-Jeff C.
Old Aug 18, 2003 | 01:01 PM
Benny Hinn's Avatar
Default Re: b20 vtec timong belt and tensioner (jcda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcda6 &raquo;</TD></TR><TR><TD CLASS="quote">What ever oil pump you use dictates which belt you will need. In your case, since you're using the ITR oil pump, you will need to purchase the GSR/ITR timing belt from now on.
-Jeff C.</TD></TR></TABLE>
The water pump dictates the belt.
Old Aug 18, 2003 | 01:07 PM
jcda6's Avatar
Default Re: b20 vtec timong belt and tensioner (Benny Hinn)
oops, HUGE typo...the water pump dictates which belt you uses.
Thanks Benny for catching that
-Jeff C.
ekturbohatch22
May 11, 2007 07:25 PM
mycrx7
14
Jun 14, 2005 02:14 AM
projectTeG
Oct 28, 2003 02:31 PM
Norcalstoppy
Aug 7, 2003 01:13 PM
88B20CRX
Apr 17, 2003 05:23 PM
