Compression Check= low compression?
Old Aug 18, 2003 | 06:33 AM
genetsang's Avatar
Default Compression Check= low compression?
just did a compression check on the gsr... the compression for all 4 cylinders are well below 200... all 4 cylinders are running around 140-160... Would the cam gear setting contribute to the low compression? since the valves are some what opened and its leaking pressure? or would it be a burnt piston ring or two..
Modified by genetsang at 1:01 PM 8/18/2003
Old Aug 18, 2003 | 09:01 AM
genetsang's Avatar
Default Re: Compression Check= low compression? (genetsang)
Old Aug 18, 2003 | 09:11 AM
sackdz's Avatar
Did you perform the test with the throttle open?
Old Aug 18, 2003 | 09:19 AM
genetsang's Avatar
Default Re: Compression Check= low compression? (sackdz)
well i unclipped the distributor harness. and started the car.... would would the throttle be open? i didnt step on the gas pedal either. so i dont think the throttle was open
Old Aug 18, 2003 | 09:49 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genetsang &raquo;</TD></TR><TR><TD CLASS="quote">well i unclipped the distributor harness. and started the car.... would would the throttle be open? i didnt step on the gas pedal either. so i dont think the throttle was open</TD></TR></TABLE>
usually when doing a compression test, you want to have the TB open at W.O.T. for the best results. Try doing it again w/the throttle pressed while cranking the engine.
Old Aug 18, 2003 | 12:03 PM
genetsang's Avatar
Default Re: Compression Check= low compression? (Katman)
thanks a bunch Katman.
young geezer
20
May 6, 2010 08:22 AM
lee0149
Feb 6, 2009 10:33 AM
MrMug3n
Jul 14, 2008 04:02 AM
anth2k4
Mar 25, 2008 06:20 PM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
