How do you take off the rubber brake line on the rear disc brakes?
how do u remove the rubber brake line from where it goes from a steel line into a rubber piece. on the end of the steel line is a 10 mm hex where i can put a wrench to take off the steel line, but the rubber line is still connected. so do i remove the rubber line without stripping or ruining it?
From: Formerly of SF moved to DFW and now back in SF, CA, USA
There is a clip that holds the line. You need to pop/slide that off before you can remove the rubber line.
hondazccivic
Aug 21, 2008 11:41 AM
