the wildest S***
changing clutch right and drop the tranny i see bent fingers on the pressure plate so i take it off that where i see the wildest **** clutch was so gone in had raw metal on both sides and a spring had popped out, plus you know a flywheel bolt has about 12 teeth on it the clutch had none it looked like one big as rib-it. the bolt just fell the hell out. and the bad part is that i can't get another one until honda opens up Monday.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 »</TD></TR><TR><TD CLASS="quote">changing clutch right and drop the tranny i see bent fingers on the pressure plate so i take it off that where i see the wildest **** clutch was so gone in had raw metal on both sides and a spring had popped out, plus you know a flywheel bolt has about 12 teeth on it the clutch had none it looked like one big as rib-it. the bolt just fell the hell out. and the bad part is that i can't get another one until honda opens up Monday.</TD></TR></TABLE>
. < use a few more of em. i only saw 2 in your whole paragraph. itll make it a lot more understandable.
m015094
Feb 19, 2007 11:44 AM
