Smoking steering column, not holding idle, won't start etc... what's wrong?
Old Aug 17, 2003 | 03:48 PM
camera obscura's Avatar
Default Smoking steering column, not holding idle, won't start etc... what's wrong?
The last few times I've tried to start my CRX, the car will start for a second and then immediately die. If I wait 6-8 hours... the car will eventually start just fine.
Today I started it... seemed to be doing just fine... drove it around for about 30 minutes until I started to smell something really weird. Then smoke appeared from behind the steering wheel (WTF?), idle rev's started fluctuating and it died.
I already know I have a bad main relay, but I don't think that is necessarily the problem here. Does it just sound like an electrical problem, alternator maybe? Any help is appreciated.
Old Aug 17, 2003 | 04:40 PM
ThatRicerDaniel's Avatar
Default Re: Smoking steering column, not holding idle, won't start etc... what's wrong? (camera obscura)
some wire probably grounded out.
Old Aug 17, 2003 | 06:39 PM
onePOINTsix's Avatar
Default Re: Smoking steering column, not holding idle, won't start etc... what's wrong? (NitrousDreamz)
ya a wire grounded out more then likly, this one time in my friends truck a wire grounded and caught fire, he went the hospital for somke inalation, + wires and a - grounded chassie dont mix
Old Aug 17, 2003 | 08:19 PM
BMacls's Avatar
it can also be the start wires behind the key. remove the plastic around the steering column you will see the silver cyclinder for your key and a white plastic piece screwed to it. it could be that piece there.
Old Aug 17, 2003 | 11:32 PM
ElementMotor's Avatar
When my ignition switch started going bad, it started smoking.....replaced it and its all good, thru a hook-up at Honda I got it for like $43...
7andaswitchblade
May 26, 2009 08:10 PM
jmpgraphy
Dec 30, 2007 09:39 PM
G0crxG0
25
Aug 29, 2006 06:15 AM
90civichb
21
Jul 29, 2005 10:50 AM
Rain_man
Feb 10, 2003 01:52 PM
