Intake Installation Tecniques (5th Gen)
Old Aug 17, 2003 | 11:59 AM
DrunkNRacer's Avatar
Default Intake Installation Tecniques (5th Gen)
Can I see some examples of everyones Intake Installations on their 5th gen Accords (I-4 only please).. I currently fell into the possesion of a short ram from my friends gs-r.. It looks like a tight squeeze.. Just wanted to know and see (prefferably pictures) of how your intake installation is in-tact.. thank you in advance.
Old Aug 17, 2003 | 12:41 PM
swoosher21's Avatar
the piping of the intake will be bigger than your throttle body inlet. you could make it fit, but it will be bootleg as hell.
Old Aug 18, 2003 | 05:48 AM
Default Re: (swoosher21)
Im under the impression that my throttle inlet is 60mm as well as a b18c .. right?
Old Aug 18, 2003 | 06:15 AM
swoosher21's Avatar
unless you have an aftermarket throttle body, your inlet will be smaller than that of the bi18c. im not sure of the sizes on the throttle bodies, i just know from experience that the bi18c has a larger diameter.
Old Aug 18, 2003 | 07:06 AM
Hondaswap.com's shizing chart says they are both 60mm.. unless you can find some other source that says otherwise.
Old Aug 18, 2003 | 07:17 AM
Nick M's Avatar
Default Re: (G-villeRacer)
it will just hang there unless you fabricate a bracket that fits
you really found ZERO pictures when you searched??
Old Aug 18, 2003 | 11:03 AM
Default Re: (Nick M)
havent found any..
Old Aug 19, 2003 | 12:55 AM
TypeSH's Avatar
http://www.hondalive.net/lorda....html
from LordAccord (old school hondasociety guy)
Poppins324
17
Jan 25, 2008 01:10 PM
Deej
Sep 26, 2006 05:32 PM
cbmprelude
Jul 28, 2004 07:37 PM
LudeAchris2001
Jul 13, 2004 11:39 AM
