TPS Problem: Inverted Voltage
Old Aug 17, 2003 | 09:34 AM
Darkteg's Avatar
New User
Default TPS Problem: Inverted Voltage
i can't seem to adjust the correct voltage right on my TPS.
it reads 4.6V @ Idle and 0.45V @ WOT....
do i have any switched wires..?
thanx in advance
Old Aug 17, 2003 | 10:56 AM
fox297's Avatar
Default Re: TPS Problem: Inverted Voltage (Darkteg)
Did you reverse the TPS when you install it? Fully closed throttle should read around .45-.5V and should not exceed 1V at wot.
Old Aug 17, 2003 | 10:58 AM
simple4012's Avatar
New User
Default Re: TPS Problem: Inverted Voltage (fox297)
sounds lke it backwards to me
Old Aug 17, 2003 | 12:47 PM
Darkteg's Avatar
New User
there's no way i could plug the TPS backwards, and i have no ecu codes at all.
here's a diagram of the wiring:
_____/ \_____
| 1 | 2 | 3 |
1 - Ground
2 - Postive
3 - ECU 5v
i used 1 & 2 to adjust, but i have no explanation for the reversed voltage
bam_89
Feb 3, 2010 02:55 PM
1Bluegsr
Jan 16, 2010 12:12 PM
lshatch1.8
Jan 8, 2008 12:33 AM
VAturbob20
Dec 28, 2005 05:55 PM
wade
May 31, 2004 12:32 AM
