Alignment ??
Old Aug 17, 2003 | 07:17 AM
ultimatehonda's Avatar
Default Alignment ??
Will dropping the tranny cause the alignment to go off?
TIA
Old Aug 17, 2003 | 07:36 AM
AngryTroll's Avatar
Default Re: Alignment ?? (ultimatehonda)
What model do you have? If any part of the sub frame is removed, the alignment will shift (just a little). If you use the alignment holes in the subframe and if you are carefull to match the the head of the bolts with the old marks on the subframe, you will have it aligned almost perfect...
Old Aug 17, 2003 | 09:09 AM
Default Re: Alignment ?? (AngryTroll)
Im talking about the tranny, like you have to take off the axels and the lower ball joints. Will doing this mess up the wheel alignment in the front?
Old Aug 17, 2003 | 10:28 AM
AngryTroll's Avatar
Dude...Some models (Accord, etc.) require you to remove part of the subframe when you remove the tranny. Some models do not (Civic, Integra)....
And, no... Lower balljoints and axles won't change your alignment.
Old Aug 17, 2003 | 10:32 AM
Oh...I have a civic si, but I didnt know there was any subframe removal involved.
projsectEF
May 22, 2006 08:36 PM
freakasis
Apr 18, 2006 10:34 AM
IMSTOCK
Dec 2, 2005 04:46 PM
Blaze45
Dec 3, 2002 03:24 PM
chrisITR
Sep 9, 2002 08:20 AM
