Throttle body install questions/woes/review....
I got a 70->68mm TB and I swapped the sensors over..
The Questions:
My idle is slightly high(tried to recalibrate the tps sensor already) and the throttle cable adj. all the way out
It revs up to 1.5k till I come to A COMPLETE STOP.
My car smells like rotten egg, when it rev's up.
Fans don't come on as often.
Also the TB didn't have a line for the coolant so i "linked" them together w/ aluminum tubing and clamped it down. holds tight, its so it bypass the TB area... or should i plug the whole thing up on both sides?
And i have an extra "nozzle" the brass one on top.. what goes there?
also.. i think my gas milage has gone to hell..
the quality on the piece is great though.. pics below.
Please any help is appreciated guys.. thanks.
I'll give a review after.. but as of now..throttle response is great, butt dyno feels gains all around.. mostly 3k+
If you guy are wondering why i got this mod on a stock motor.. its b/c i traded it for a STOCK USDM TB + 5 Dollars. and 5 more for a tb gasket. it cost me 10 bux for this
Big thanks to the guy who traded me
i will be purchasing a portflow ported itr manifold, so its port matched.
where i looped the coolant hoses
Shot of the throttle cable adj alll the way out.
Modified by 00 FBP ItR at 4:51 AM 8/19/2003
The Questions:
I have a 70mm tb as well without the above mentioned. Connecting the coolant hoses to bypass the tb is fine. Only reason I connected them is to see if it was 'cooler' with the hondata gasket.
As far as gas mileage, hard to say, I have a semi-built motor with a higher fd and I still great gas mileage.
I did have a high idle when first using the tb, but I just played with the idle screw and it was corrected. Btw, I have a bbk tb, no throttle stick, no throwing codes.
You can just plug the top spout, most likely that is for obd 1 cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jsracingintegra »</TD></TR><TR><TD CLASS="quote">When you installed the TPS sensor you need a volt meter. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">
I did.. its a OHM Meter not volts, Nice try though.
afaik, when u add a bigger throttle body the car will run leaner, u might want to get it re-tuned to take full advantage of your new mod...
you might even be running too lean right now.
yea i'm waiting for a port matched IM.. before any tuning.. i'm running kenji's prog. i think i'm still rich at the moment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">I got a 70->68mm TB and I swapped the sensors over..
The Questions:
Anybody know?
The Questions:
Anybody know?
I'm assuming you idle correctly when you've come to a complete stop. I"ve had the same problem before which I attributed to the TPS (it stands for throttle position sensor, no need to say tps sensor..
, that's like saying HIV virus or AIDS syndrome).. anyways I didn't have a multi-meter when I installed my TB and so I had to manually adjust the TPS until it wouldn't rev so high when coasting.. also what exactly do you mean the throttle cable is adjust all the way out? i believe if it's too tight you will see a fluctuating idle.. use the idle adjust screw to adjust idle.. i also had to adjust the throttle stop screw when I installed my TB, only because it closed a bit too deep into the bore and would stick on accel..
after manual adjustment of TPS, I ended up with a reasonable 'rev up' on coast which sort of went away after driving around like that for a while.. strangely if I reset the computer, this 'rev up' will re-appear only to disappear with some driving.
, that's like saying HIV virus or AIDS syndrome).. anyways I didn't have a multi-meter when I installed my TB and so I had to manually adjust the TPS until it wouldn't rev so high when coasting.. also what exactly do you mean the throttle cable is adjust all the way out? i believe if it's too tight you will see a fluctuating idle.. use the idle adjust screw to adjust idle.. i also had to adjust the throttle stop screw when I installed my TB, only because it closed a bit too deep into the bore and would stick on accel..after manual adjustment of TPS, I ended up with a reasonable 'rev up' on coast which sort of went away after driving around like that for a while.. strangely if I reset the computer, this 'rev up' will re-appear only to disappear with some driving.
im running a 66/68mm TB by Ericks Racing with no problem , will up grade to 70/72mm real soon . But then again i had it install by them and they fix the problem that you had .( not as much but at least the high rev part 1.5k) check on the TB sensor ...
What i mean by the throttle cable is all the way out is its adjusted out to its max point(loose setting).
and i did recalibrate my tps sensor.
Did you check the map sensor?
As for the throttle cable mine is set up just like yours. I backed the nut all the way back so it was not even on the threads of the cable and then used the other bolt to tighten it down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x »</TD></TR><TR><TD CLASS="quote">tb gasket upside down?</TD></TR></TABLE>
Nope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rolow »</TD></TR><TR><TD CLASS="quote">Did you check the map sensor?
As for the throttle cable mine is set up just like yours. I backed the nut all the way back so it was not even on the threads of the cable and then used the other bolt to tighten it down.</TD></TR></TABLE>
Not the map either.. i'm not throwing any codes..
Nope.
hkrichard
Apr 27, 2008 06:03 PM
c1_inside
Dec 13, 2007 09:15 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
