88 crx si with a b18a1.....need header, down pipe, cat, and exhaust that will fit...please help!!!
Old Aug 16, 2003 | 05:29 PM
vtec95's Avatar
Default 88 crx si with a b18a1.....need header, down pipe, cat, and exhaust that will fit...please help!!!
I have a 88 crx si with a 91 integra ls motor (b18a1). It needs a header , a down pipe that will clear the oil pan, a cat, and a cat back exhaust. If anyone has this set up can you please tell me what will fit on this crx? Any help would be appreciated.
Old Aug 17, 2003 | 02:35 AM
civickiller's Avatar
Default Re: 88 crx si with a b18a1.....need header, down pipe, cat, and exhaust that will fit...please help!
buy a 91 integra header, like a dc sports or something. and for the cat go to a muffler shop and haave them make u a straight pipe. and well buy a catback system
Old Aug 17, 2003 | 04:47 AM
NCchris's Avatar
On my B18b swap, I'm using a 97 GSR (stock cast iron and tube) tri-y exhaust. Carsound 2-1/4 cat with a greddy mx catback. I like it. Use muffler shop to weld cat to stock flanges. One thing to look out for on the header, the LS header is longer on the collector end, GSR is shorter. So if you use the GSR system, or aftermarket header, the cat adapter will need to be longer. You could use the stock Si cat and exhaust, I think the LS will bolt up, but the GSR is too short.
HTH
chris
Old Aug 17, 2003 | 05:07 AM
RotiEatter's Avatar
Ditto
If you want factory then use the LS exhaust manifold and the d16 downpipe. They bolt right up adn will bolt to your stock cat.
Broken Devil
Oct 3, 2005 09:55 PM
honda95civic
Welding / Fabrication
Aug 28, 2005 05:31 PM
jdmxxdc2
Jan 13, 2005 11:26 AM
Hybrid2Be
Dec 18, 2003 07:33 PM
JCushing
Mar 28, 2002 06:56 PM
