JDM B18C-R, unknown vacuum line?
Does anybody have any idea what this line goes to? It's the small gray line near the larger brake booster hose in this pic, coming out the back of the intake manifold. The engine is a 99 JDM ITR B18C. The hose came already attached when we got the engine swap, and is about 14" long.
No clue as to what it is. But if you remove it, the idle will be effected. Basically, it will bring the idle up about 250-300 rpms.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I just went to check it out on my car and it looks like it goes to a black box looking thing underneath the manifold. Hopefully you have this too. I don't know what it is. The "black box" has two hose outlets. One hose goes to the charcoal canister and the other is to the other end of the vacuum hose you are referring to. My shop had to "mickey mouse" a larger hose over the end on the "black box" and stick the vacuum hose in the larger hose and held it in place with a clamp. I'll have to re-do that one day.
Hope this helps. Sorry, my camera just died and I don't have any pics. If I can get some I'll post them up. Although the angle will make it tough for a good picture.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 »</TD></TR><TR><TD CLASS="quote"> it looks like it goes to a black box looking thing underneath the manifold. .</TD></TR></TABLE>
yup.....goes to that vacuum box....
no cruise Control on JDM R's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flex97itr »</TD></TR><TR><TD CLASS="quote">i always thought it had something to do with cruise control</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">no cruise Control on JDM R's
MiraiZ, can you tell us what it's for, and if it's supposed to connect to that vaccuum box?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Does anybody have any idea what this line goes to? </TD></TR></TABLE>
It goes all the way to the charcoal canister.
The "Little black box" that the vacuum line goes to is the evap purge. It is part of the emmisions control system.
Basically it vents vapours captured in the charcoal canister into the intake tract at startup.
You can just plug the fitting into the IM if you like ... but the smog police may be ansy
Cheers
Moose
when i dug around in the engine bay today i couldn't find a place to plug it into. nothing on the evap canister for it. nothing on the charcoal canister looked like it would fit either. if i plug it the idle comes up a little too high for my liking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamITR »</TD></TR><TR><TD CLASS="quote">On my B16B ... I have it going to the EVAP purge valve</TD></TR></TABLE>
Goes to the purge
Goes to the purge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">I can tell you where mine goes tomorrow (never noticed it before)...keep this post alive!!</TD></TR></TABLE>
If you could look and find out for us that would be great.
I hate working on swaps and not having them run right.
bump bump, any info MiraiZ? I have that running to the evap canister on my friends integra with skunk 2 manifold. I don't see where else it would go.
</TD></TR></TABLE>bump bump, any info MiraiZ? I have that running to the evap canister on my friends integra with skunk 2 manifold. I don't see where else it would go.
89sicivic
Jan 31, 2006 08:19 PM
Louie_EM1
12
Feb 27, 2005 11:16 AM
PatrickGSR94
Aug 17, 2003 12:22 AM
