Instrument Cluster Help
What type of bulb illuminates the speedo and tach?
Also does anyone know how to get the instument cluster out from behind there? Does anyone have any diagrams showing how to do it?
Thanks
Thanks
the bulbs are just 3 little wedge bulbs as in your front bumper turnsignals.
take out your cluster by removing the 2 screws on the top of the bezel, becareful not to drop them into the steering collumn hole of no return
... anyway pull the bezel thing out with both hands from the bottom wiggleing it back and fourth. it will seem like it doesnt want to come out but it will. then there are 3 screws holding the cluster in. take them all out and pull the cluster out and take out the wires that are cliped in so you can take the cluster out all the way. then you will see little black ***** that are the bulb sockets. it will be obvious which ones are for what. just take the old bulb out and put the new one in. put all the clips back into the back of the cluster and put everything back and your done
pull the top of the bezel enough so you can get your hand behind the bottom piece. then just pull. it won't break it just feels like its going to.
oh yeah and the bulb is 194. Same as your sidemarkers.
[Modified by gsr squirrel, 7:45 PM 8/12/2001]
http://www.team-integra.net/ti/proje...tall/index.asp here are some instructions with pictures that should help u get the cluster out, later
... I thought the sidemarkers were bulb number 168? I've bought those and they fit..
We're talking about the turning signal/bumper lens/corner light, correct? The outside bulb? Where the inside bulb is number 1156.
Eh?
Eh?
jdmcivicracer89
May 31, 2008 10:23 AM
RHGSR01
Dec 11, 2001 07:46 AM
