wheel shakes around 80 km
Old Aug 16, 2003 | 12:04 PM
sikcrx80's Avatar
Default wheel shakes around 80 km
well as long as i know ive have this shake in my cars steering wheel.
when im doing 80 it shakes anything over 120 it is fine..
now my camber is bad 3 deg out would that make the prob?
i was thinking that it could be steering rack. ive check tie rod ends there good..
im not to sure now
Old Aug 16, 2003 | 05:13 PM
tony's Avatar
Default Re: wheel shakes around 80 km (sikcrx80)
bump^^^
Old Aug 16, 2003 | 06:43 PM
blah13's Avatar
Default Re: wheel shakes around 80 km (tony)
Raise the car and jerk on the tires, there shouldnt be any play. If there isnt any then get your tires balanced. If it does have play describe it so we can help with which suspension part could be messed up.
Old Aug 16, 2003 | 07:19 PM
4crx4me's Avatar
If your steering shakes ONLY at certain specific speeds and then goes away when you change speeds, in my experience that usually means one thing. Your wheels need to be rebalanced. Check that first BEFORE you do anything else.
HTH
Old Aug 16, 2003 | 09:44 PM
biggdogg's Avatar
Default Re: wheel shakes around 80 km (4crx4me)
upper balljoints. had the same prob for years then finally i get spc adjustables and it`s gone
Old Aug 19, 2003 | 08:55 AM
machine4321's Avatar
sounds like ball joints to me ...
Old Aug 19, 2003 | 09:21 AM
Vinceg99's Avatar
Default Re: (machine4321)
I would start simple and see if your tires are balanced correctly like they said above, but on another note how old are your tires?? Have they sat for any lengths of time?? Any that are bald? What size and brand are they also?
Old Aug 24, 2003 | 06:46 PM
sikcrx80's Avatar
well my tire are not even a year old.
and even with my old rims i had the shake.
for some reason i dont think it is tires tie rods are good and as far as i know everything else is too..
i was thinking it was something in steering rack and was wondering if anybody else has this prob.
Old Aug 25, 2003 | 01:52 AM
Mr.Saturn's Avatar
Default Re: (sikcrx80)
Rebalance the wheels, even if you had it with old wheels just do it. If you've ever used an old on-car balancer, you will understand how much 1 gram off on a single wheel can shake the whole car.
SPOOLINmatt
May 29, 2008 11:16 PM
Jer'rome
Aug 12, 2003 08:24 PM
ransack
10
Aug 10, 2002 07:45 AM
i_krayzie_i
Apr 6, 2002 08:04 AM
JDMgizmoDC2
Feb 20, 2002 05:54 PM
