camber
Old Aug 16, 2003 | 08:00 AM
tdr-'s Avatar
Default camber
i have a pair of progress camber kit. but for some reason the fron upper arm-hit.
is there a way to fix the problem (so it wont hit anymore)
Old Aug 18, 2003 | 04:48 AM
krotchwaffle's Avatar
Default Re: camber (tdr-)
try a search, this has been covered many times.
you'll have to do a combination of banging out the fender well and shaving the end of the control arm. remember that you don't have to correct the camber completely, just as much as possible before it hits, and it will still help.
Old Aug 18, 2003 | 02:11 PM
tdr-'s Avatar
Default Re: camber (krotchwaffle)
thanks for info?
Old Aug 18, 2003 | 02:32 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdr- &raquo;</TD></TR><TR><TD CLASS="quote">i have a pair of progress camber kit. but for some reason the fron upper arm-hit.
is there a way to fix the problem (so it wont hit anymore)</TD></TR></TABLE>
It is because you have a lot of negative camber... and because you've adjusted it with the camber kit... this helps pushed your tires out preventing them from cambering, but in turn also pushed your control arms out which hits against your inner fender wall. A) raise your car so the control arm wont hit B) Don't adjust your camber to the max, but then remember it will wear out. C) Try shaving your ball joint and inner fender wall. I chose C myself and its worked fine. But i did change to a bit higher sport springs.
Old Aug 18, 2003 | 09:11 PM
SiR EJ8's Avatar
i have a 90 with a sprint camber kit, but i never ran into the problem of upper control arm ("A arms") hitting the fender or rubbing. you could try coilovers or if your struts are bad, replacing those could give you that little bit of extra room to keep you from scraping.
Old Aug 19, 2003 | 09:11 AM
tdr-'s Avatar
thanks to all for the info..
garyc17
Apr 17, 2008 08:38 AM
guero2craze
Suspension & Brakes
Feb 22, 2007 09:53 AM
budget
Suspension & Brakes
Apr 13, 2005 02:54 PM
SL!M
17
Feb 27, 2005 04:47 AM
Kyles ej1
26
Nov 19, 2004 06:09 AM
