How is camber with everyone?
I have blown shocks on H&R springs. The camber is way off, my tires are already shot after about 6 months. I was hoping that with my new KYB AGX installed it will fix the problem. Should i get camber plates also, or a kit? Let me know thanks.
Re: How is camber with everyone? (SL!M)
camber? whats camber, i dont have any! if your camber is that bad get a kit for the front and make one for the rear and then get it alinged, how much did u lower. i have 1 finger gap and i dont have any problems
most hood white kid
Re: How is camber with everyone? (93blkej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">camber? whats camber, i dont have any! if your camber is that bad get a kit for the front and make one for the rear and then get it alinged, how much did u lower. i have 1 finger gap and i dont have any problems</TD></TR></TABLE>
how would you make one for the rear...shouldnt a kit take care of both the front and the rear?
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">a long bolt and some washers. its like $6 compared to like $100 or w/e the price is</TD></TR></TABLE>
how does this fix camber...i have always been in the dark when it comes to camber
Re: How is camber with everyone? (egcoupe94)
when u lower your car u get negative camber like this /
the more washers u use the more positive camber u get \
u have / neg camber and put some \ positive camber u get l which is 0 camber
sorry its not that good.
Re: (SL!M)
Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">whats the difference between camber and toe?</TD></TR></TABLE>
hope this helps
hope this helps
im on neuspeed race springs with stock shocks about to blow...no gap between the fenders and tires...no camber issues really...it's noticeable more on the the fronts, but it doesnt look too bad
Re: How is camber with everyone? (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">I'm lowered with no fender gap. No uneven wear at all. No camber kit.</TD></TR></TABLE>
Me too, i used to be on stock shocks and r1 coilovers...no problems at all. I didnt even need an alignment.
You should always get an alignment done after any suspension work if you have any doubts or if your car wanders driving down road
be professional
Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">and when u get an alignment..do they check for all of this?</TD></TR></TABLE>
Yes - however, only toe is adjustable on a stock Honda double wishbone suspension. Camber and caster are not adjustable without aftermarket suspension components.
Toe is the major factor in uneven tire wear anyway. Camber and caster do not play as significant of a role.
