How to properly advance timing?
Old Aug 12, 2001 | 10:35 AM
tampaSi's Avatar
New User
Default How to properly advance timing?
I've read all the various how-to's, but i'm still a little confused about the jumper setup and whether it can be done without a timing gun. I only want to advance it a little bit--i think it may be off as well. Any suggestions would be much appreciated.
Old Aug 12, 2001 | 03:38 PM
mr.sleeper's Avatar
Banned
From: PUT BACK MY AVATAR YOU FUCKING FAG MODERATORS, canada
Default Re: How to properly advance timing? (tampaSi)
use a timing gun. only way you know for sure.
Old Aug 12, 2001 | 03:45 PM
chri5's Avatar
Default Re: How to properly advance timing? (mr.sleeper)
you can adjust it without a timing gun, but you can also skydive without a parachute. I wouldn't want to do either without the right equipment.
Old Aug 12, 2001 | 11:01 PM
b18bvudoo's Avatar
New User
Default Re: How to properly advance timing? (Strng1dah)
those timing guns are expensive. try borrowing one if you can, unless for some reason you plan on changing yor timing frequently.
Old Aug 16, 2001 | 07:36 AM
carolinaACCORD's Avatar
Default Re: How to properly advance timing? (vudoo666)
how do you change your timing.how do you know what to set it at?
Old Aug 16, 2001 | 04:16 PM
ringgold's Avatar
Default Re: How to properly advance timing? (HONDApowerEXTREME)
You loosen your distributor and adjust. But it is always best to have a timing light or else you will not know what it is set at. Also you need to have the jumper hooked up. Get a repair manual tells how to do everything pretty much.
brokenojoke
Engine Management and Tuning
Jun 14, 2008 09:50 PM
sikek1
Apr 28, 2008 05:49 AM
civic j
Aug 17, 2007 08:10 AM
kixcrx
Nov 10, 2006 10:33 AM
Tx92AccordExD
Jul 22, 2002 11:13 PM
