Something wrong in cylinder #4, help.
when changin my plugs I noticed that in the #4 cyl that I had a decent amount of oil over the plug. I could do a compression test and I'm sure it'd confirm that something is wrong. When the car fisrt starts up a little smoke comes out of the tail pipe. Plus my tail pipe has a black power like stuff all on the inside. My questions is more of what might be wrong.
One of my friends sugested that it might be the head gasket seal, I'm hopping it's something simple.
So what do you guys think it is? How hard is it to replace the head gasket.
Well it could be a couple of things. It could be the piston rings or the spark plug cover grommets. A lot of people will tell you if the oil is on the bottom of the plug, its the rings. And if its on the top its the spark plug cover grommets. But I have worked on many cars with the same problem you have and it turned out the spark plug grommets were really bad. So before you tear apart the engine I would change the spark plug grommets to make sure its not those.
i actually just finished changin my plugs and wires about 20minutes ago and had oil on like the bottom of 2 plugs....but my car smokes cause i have a bad bottom end....my rod knocks too....but i have bad main bearings or something along them lines...thats most likely why my plugs were oily
I noticed some light gray or white smoke coming from my exhaust. I was stopped at a light and reved to about 3K. Was able to notice some white smoke out my side mirror.
Idea's if it might be part of the same problem? Other ideas?
im not sure if this is true, but someone told me that white smoke is bad..and if its black smoke its ok. black means oil and white means coolant? it could be valve seals.
phaphon
24
Apr 13, 2017 09:00 AM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
93SSPHatch
May 30, 2002 04:27 PM
