Finally got around to starting on my 3" downpipe...
Old Aug 15, 2003 | 04:28 AM
SiR Kid's Avatar
New User
Default Finally got around to starting on my 3" downpipe... EDIT More Pics!
Well, I got all the bends and flanges together, and I finally persuaded my best buddy Alan to start helping me mock up the downpipe. This turned out to be quite the task. ED chassis cars were NOT meant to be turbo'd, and DEFINITELY not meant to have 3" downpipes of any sort.
You can see all the tight radius bends we had to use on this thing... JEEZ!
This WAS a 3" radius 3" piping donut that I picked up from http://www.roadraceengineering.com , it's a really nice little piece of metal, too bad we had to go and cut it up so much. For smoother flow out of the exhaust housing, and to help fitment of bolts and stuff to the turbine housing, we used a very short length transition to go from a 2.5" housing outlet up to the 3" piping for the downpipe for minimum backpressure in the system. Hopefully with this setup, the flow characteristics will allow for a great exhaust evacuation setup.
We're about 50% there as these pics were taken tonight. We've still got a little work to do with the oil return line, and the closed loop wastegate I want to use. It's getting there...
PS, there's about 3/8th of an inch between the Jimfab bars and the lower bend in these pics... We "cheated" VERY slightly, and offset the bend at the top by about 1/32 and pushed the flange up as high as it would go to keep things spaced as much as possible. I hate the ED chassis sometimes. :angry:
Modified by SiR Kid at 8:28 AM 8/19/2003
Old Aug 15, 2003 | 04:32 AM
Burke's Avatar
Banned
Default Re: Finally got around to starting on my 3" downpipe... (SiR Kid)
hey - looks GREAT MAN!! isnt it fun to DIY. i did all my exhaust myself, fun stuff and only one way to learn
keep up the good work!
Old Aug 15, 2003 | 05:20 AM
Prelude Vtec 23's Avatar
Default Re: Finally got around to starting on my 3" downpipe... (Burke)
Looks great!! Let us know how everything turns out.
Old Aug 15, 2003 | 05:49 AM
JeremyL's Avatar
Default Re: Finally got around to starting on my 3" downpipe... (Prelude Vtec 23)
why is your compressor turned upwards?
Old Aug 15, 2003 | 06:00 AM
FOrSfEd's Avatar
Default Re: Finally got around to starting on my 3" downpipe... (JeremyL)
Looks pretty good man.
Old Aug 15, 2003 | 06:08 AM
SiR Kid's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">why is your compressor turned upwards?</TD></TR></TABLE>
Water/air intercooled.
Old Aug 15, 2003 | 06:46 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Nice work dude. I love air/water on the street.
Old Aug 15, 2003 | 08:25 AM
Doodoo's Avatar
This is what I have been trying to do for almost a year. Nice! I would like to see how you do your -10 return line though. Whenever I look at my setup that line is my main concern. Thanks.
Old Aug 15, 2003 | 09:09 AM
VTC_CiViC's Avatar
Default Re: Finally got around to starting on my 3" downpipe... (Doodoo)
Wow.. VERY nice!
Old Aug 15, 2003 | 09:12 PM
SiR Kid's Avatar
New User
Default Re: Finally got around to starting on my 3" downpipe... (VTC_CiViC)
We're planning on runnint the -10 return to the radiator, then use a pretty long return line with a slope still to it, and have it drain around the OUTSIDE of the downpipe to finally meet back up with the fitting from the oilpan. We're having to do this, because the DP gets in the way of the ENTIRE large part of the oilpan with the JimFab bars... Those things had better help traction A LOT, because they're becoming a PITA to work around.
Old Aug 16, 2003 | 01:13 AM
SiRkid's Avatar
sweeeeeet.
I couldnt do a straight 3"
i have 2.5" flared to 3 mind you the 2.5" section is only about 3 inches long then it flares.
Old Aug 16, 2003 | 02:11 AM
SiR Kid's Avatar
New User
Default Re: Finally got around to starting on my 3" downpipe... (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">For smoother flow out of the exhaust housing, and to help fitment of bolts and stuff to the turbine housing, we used a very short length transition to go from a 2.5" housing outlet up to the 3" piping for the downpipe for minimum backpressure in the system. Hopefully with this setup, the flow characteristics will allow for a great exhaust evacuation setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">sweeeeeet.
Same here. The 2.5" in mine is MAYBE 1.5" to 2" long coming straight off the turbine flange.
Old Aug 19, 2003 | 05:27 AM
SiR Kid's Avatar
New User
Got some more pics last night of progress....
Welded up the Donut pieces, added a little more tubing, adn got some good pics of the 2.5" to 3" transition.
Whatcha think?
Old Aug 19, 2003 | 08:43 AM
ScottEK's Avatar
I have one of these for sale brand new with pump, fittings, and the water line for $300 if anyone is interested, I went with a FMIC instead.
EDIT: After seeing your pic I kind of wished I used it...
BlueShadow
Feb 14, 2005 12:34 PM
AspectIndustries
Apr 10, 2004 12:23 PM
calib17a
Feb 17, 2004 08:27 AM
pub
Apr 28, 2003 10:22 AM
integranator
Mar 26, 2003 03:44 PM
