Water go into the trunk.....
It's pouring rain today, and no I didn't leave the trunk open.
When I put back the spare and ready to go home, I found out the trunk (where the spare tires is) is flooded with water around 3 inches deep! Anyone have clue where those water coming from? I am sure it's not a leak from above, cuz my trunk carpets are dry.
it may not help - but i had a BIG leak problem in my old accord, found out it was through the tail-lights - best bet is to drop the back seat (get in)and (have a buddy) soak the trunk area to see (hopefully) where it is coming from - it could be coming from the sides or somethin' sounds odd cause trunk carpet was not wet
[Modified by 2000-4DRGSR, 11:39 PM 8/11/2001]
i also have a leak problem..not the same but its a leak. Whenever i wash my car...i find that water has somehow found its way through everything down my side panel, and leaked out of my speaker grille...any explanation?
i have a small leak in the trunk also. and like george said... good chance it's the seals on tht tailights... i dunno where the **** mine comes from... i've done the whole sit in trunk while buddy hoses car down.... oh welll....
D
D
My taillight gaskets went and wrecked my subwoofer enclosure which sat in the spare tire well. 33503-ST7-AO1 is the part number. They're about $29 a piece.
If it's the tail-light gasket problem, then it's a free warranty item (granted your under 4yr/50kmiles). I had it done on my Civic. The only thing is if your taillight is leaking, then you should see a condensation inside the lenses.
bing*bing*bing*bing*!!!!
yup, replace those and viola, no more water in the trunk.... happended in my '94 teg too.
crxaddikt
Oct 28, 2002 02:35 PM
