And so i dynoed my car...... Anyone got any suggestions?
Old Aug 11, 2001 | 08:13 PM
MacGyver's Avatar
Default And so i dynoed my car...... Anyone got any suggestions?
Ok i dynoed my car. and here it is.
wtf kinda honda makes peak torque at 2000 rpms and 122 ft lbs at 2000 at that?
I have some MAJOR tuning issues that need to be addressed. and some major problems that have come up. apparently i have an injectors that is working when it wants to in the #1 Cyl. so im getting a bit of detonation on the low side for some strang reason. So i have to do some major fuel adjusting. That was just the base line run right there. we tried tuning it with the VAFC and it just got worse.
well back to work fixin this ****.
when i get it tuned in it should be nice.
Mac
[Modified by MacGyver, 9:13 PM 8/11/2001]
Old Aug 11, 2001 | 08:25 PM
xjohnx's Avatar
Default Re: And so i dynoed my car...... Anyone got any suggestions? (MacGyver)
what mods? here's the dyno of my R with JDM 4-1, and AEM in 90% humidity.
Old Aug 11, 2001 | 08:30 PM
MacGyver's Avatar
Default Re: And so i dynoed my car...... Anyone got any suggestions? (xjohnx)
I was gonna write out everything but here is a link to my mods
http://forums.clubsi.com/cgi-bin/pro...rName=MacGyver
there ya go.
just add a VAFC to that list and thats what i have done.
I beleive i might have a pinched fuel line. I cant get Fuel pressure below 70 psi
which is not a good thing. which i think is what caused the injector failure in #1 there a big spooge mark under #1 injector.
Mac
Old Aug 11, 2001 | 08:34 PM
Arturbo's Avatar
Better than steak
25 Year Member
You still going party...
art
Old Aug 12, 2001 | 05:30 PM
ninjaman's Avatar
New User
You definitely need to resolve your fuel delivery problem first. 70psi is way too high. Get that injector fixed immediately. I'm also curious if your fuel curves are screwed up as well.
Another flag is that your power drops off after 7800rpm. Those cams should make peak power at about 8600rpm. Maybe some cam gear adjustment would help?
I would also recommend getting a better header than the USDM DC Sports. The skunk2 cams are too much for that header. I upgraded my USDM DC 4-1 to a JDM 4-1 and power delivery is much smoother (and increased as well).
Old Aug 12, 2001 | 05:37 PM
Black R's Avatar
25 Year Member
.....Was this just this past weekend? I don't remember seeing you there.
Maybe I was late or early...
Anyway, aren't those numbers normal for a stock itr? Or maybe the torque is a little higher than normal, but the peak whp is pretty average...
I dunno a lot about those cams... Tell us about your cam gear settings and a/f ratio ~13:1 the whole time? What about vafc settings? Where are you adding/ leaning out fuel?
Old Aug 13, 2001 | 05:44 AM
MacGyver's Avatar
Default Re: And so i dynoed my car...... Anyone got any suggestions? (Black R)
Black R I went thur. before all the hoopla happen. how did it go? Did all the vendors show up?
Mac
Old Aug 13, 2001 | 05:51 AM
Back in Black's Avatar
Rather OG
Ken~
You modified that exhaust yet? Any numbers for us? See you boys this weekend. ETD is 6:00pm from Charlotte...
Old Aug 13, 2001 | 07:25 AM
FAST94GSR's Avatar
New User
Default Re: And so i dynoed my car...... Anyone got any suggestions? (Darth VadeR)
You should putting down at least 30 more horsepower. Set your fuel press at 50 and lean out as necessary with the VAFC.
hdsupercrewf150
Honda S2000
34
Jun 23, 2007 07:51 PM
B00ST2nR
Aug 8, 2002 07:50 PM
B00ST2nR
Aug 8, 2002 01:22 PM
lilcasino
Apr 22, 2002 08:16 AM
S&P500ITR
Dec 7, 2001 06:57 PM
