block build up--need your opinon!!
Old Aug 13, 2003 | 11:51 PM
thaiphob's Avatar
Nikon!!!
Default block build up--need your opinon!!
i went to a local shop out here in Phoenix (they shall remain nameless) gave me a quote for the work i want done to my Ls block for FI. i just want you opinion about the stuff included. keeping the comp ratio around 9.5:1
~tear down/hot tank/clean block----------------------------$65
~sleeve/bore/honestep deck/ finish block to 83mm-------$880
~Arias pistions <83mm flat top>----------------------------$450
~Eagle rods----------------------------------------------------$350
~bearings------------------------------------------------------$180
~new GsR/type R oil pump-----------------------------------$125
~assemble short block----------------------------------------$275
~remove/install block-----------------------------------------$450
---------------------------------------------------------TOTAL=$3000
wadda ya think?
Old Aug 14, 2003 | 12:04 AM
TurboDANDEE's Avatar
Default Re: block build up--need your opinon!! (thaiphob)
price looks reasonable for a competent shop
Old Aug 14, 2003 | 12:33 AM
ArtOwnzMe's Avatar
why are u paying them to pull and disassemble your motor?! Were you in special ed classes or are you not allowed to use a rachet?
Old Aug 14, 2003 | 12:37 AM
flip1199's Avatar
looks good, but y are u payin them 275 to assemble the short block. If u have a helms and the right tools i'm sure u should be able to do it yourself.
Old Aug 14, 2003 | 11:28 AM
thaiphob's Avatar
Nikon!!!
Default Re: block build up--need your opinon!! (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">looks good, but y are u payin them 275 to assemble the short block. If u have a helms and the right tools i'm sure u should be able to do it yourself.</TD></TR></TABLE>
i can do it myself but my apartment is too mall for it
Old Aug 14, 2003 | 02:00 PM
ArtOwnzMe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">
i can do it myself but my apartment is too mall for it </TD></TR></TABLE>
Do you have any friends?
Old Aug 14, 2003 | 04:26 PM
Mark's Avatar
*Bounty Hunter*
Default Re: block build up--need your opinon!! (ArtOwnzMe)
Hate to steal this thread but...
Anyone have advice on a B18C1 buildup I could do? Its for a turbo, but I want to make sure the engine is damn-boost proof before I get the turbo
Any suggestions on what kind of compression and internals I should use?
Old Aug 14, 2003 | 04:30 PM
TeStUdO's Avatar
Default Re: block build up--need your opinon!! (94BlackCivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">Hate to steal this thread but...
Any suggestions on what kind of compression and internals I should use?</TD></TR></TABLE>
start your own thread, this guy has a competent question. ok back on topic, you could definitely take the engine out and at least disassemble it yourself. if youve never put an engine together before than i would definitely let them put it together. also what kinda sleeves are you getting for that price??
Old Aug 14, 2003 | 08:13 PM
thaiphob's Avatar
Nikon!!!
Default Re: block build up--need your opinon!! (TeStUdO)
darton closed deck sleeves.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
also what kinda sleeves are you getting for that price??</TD></TR></TABLE>
Old Aug 14, 2003 | 08:44 PM
RenoRacing's Avatar
That price seems a little high. two of my friend just recently got built blocks form GE. They each paid $2800 and it included complete teardown and cleaning, sleeving, boring honing, eagle rods, srp pistons, rings, bearings, crank polishing, and a completely assembled bottom end sleeved to 85mm and shipped both ways. they look bad *** too! thumbs up to GE! I will definately be contacting them soon for my own motor!
Old Aug 14, 2003 | 10:41 PM
thaiphob's Avatar
Nikon!!!
Default Re: block build up--need your opinon!! (HavokRacing)
you think i should try to get the price lower?
ERL Performance
Performance
10
Dec 16, 2010 05:41 PM
eagles3
Mar 2, 2010 03:02 PM
mtownek9
Oct 5, 2007 09:02 PM
menkio
Jun 12, 2004 10:37 AM
FOrSfEd
Feb 28, 2004 04:02 PM
