fields v-tec
Old Aug 11, 2001 | 01:59 PM
blythzithe II's Avatar
New User
Default fields v-tec
any body run a fileds v-tec controller and have the rev limiter kick @ about 5500 r'swhen you getting into the v-tec,it throws a check engine code 22,v-tec failer;or what not,not a big deal,only when i want to get into the vtec and the rev limiter kicks in, kind of suck,because i have to restart my car to reset the vtec controller,my local shop installed it and cant work out the bug>>>
Old Aug 11, 2001 | 09:23 PM
Akira-R's Avatar
Default Re: fields v-tec (blythzithe II)
What are the settings on the controller? Sometimes it doesn't like to be adjusted past 4% or the vtec more than 400 rpm.
I've had that problem many times. I just hold the button down to turn it off (not the on/off switch on the back) not worth the hassle that dumb thing.
--reid
Old Aug 11, 2001 | 09:34 PM
e's Avatar
e
New User
Default Re: fields v-tec (Akira-R)
ive been running the vtec @5100,what do your run yours @
Old Aug 11, 2001 | 09:35 PM
e's Avatar
e
New User
it has a/f,vtec,rev limiter indicator,and rpms,so forth
Old Aug 12, 2001 | 09:20 AM
Akira-R's Avatar
Default Re: fields v-tec (blythzithe)
I had mine set to 4400 (mugen ecu has it at 4700) so adjustment was 300.
And I had no more than 3% of air/fuel adjustment. And i still would have problems.
I think my issue was that the rpms were waaay off on my unit. so when i was at 7000 rpm realtime
the fields would read 8000+ and it would shut my car down at 7000 realtime.
I have since turned it off and haven't had any problems .
try this site and check your jumpers on the back of the fields to make sure they haven't
been tampered with.
http://asia.vtec.net/beystock/field/...1_sfcv0h4.html
hth
--reid
Old Aug 13, 2001 | 08:49 AM
Disco Monkey's Avatar
i dont know if its the same but my friend had a problem with his fields and he had forgotten to cut the VTM wire. the instrustions he got said nothing about it so he didnt cut it. when he did cut it that solved the problems
Old Aug 13, 2001 | 10:55 PM
DuNkiN's Avatar
New User
yea have them check out the wiring and make sure the dipsticks on the back are correct for your car. also set everything to stock and see what happens...
Old Aug 15, 2001 | 05:00 PM
tysir's Avatar
New User
Default Re: fields v-tec (DuNkiN)
when i had my on i set my at 4300 my vtec kicks in 5200 i think. but anyways when you got two device opperating a vtec theres gonna be problem and confusion on when should vtec kick in. so what i did was took that wire that connects from the vtec selinoid and connect to the controller. that solved my problem.
Old Aug 16, 2001 | 07:55 AM
New User
Default Re: fields v-tec (tysir)
cool i'll try that,i cut the vtm wire,still same problem,that sounds like it would work
Old Aug 16, 2001 | 07:59 AM
taZman's Avatar
New User
May I ask why so low???
HondacivDX
Feb 19, 2012 06:52 PM
kingh90
Honda Civic (2006 - 2015)
11
Dec 30, 2008 07:54 PM
tuckin15s_8315
Jun 21, 2005 03:13 PM
apgarabu
May 25, 2005 06:15 AM
RemerLex11
Jul 10, 2004 06:31 PM
