Hondata Stage2 PR3 problems again
Decided to get my hondata tuned earlier and after just reading the current chip for data, my ecu started to do somewhat of a count down upon start up. Throwing codes like 1, 2, 3 and so on. We reset the ecu, still the same problem. Finally, we installed a stock PR3 chip and code went away but obviously, with the mods I have this will not work...We then burned another chip with the same maps but at open loop...it kinda worked but for some reason I'm getting a code for knock sensor and car bogs between 5000-5500 rpm and runs lean at high rpm (above 8500). I wonder if this is just a wiring issue (current wire harness from hasport is a piece of crap and cracks in all places) or nonobd pr3 and hondata is a bad combo to begin with...btw, my car was running fine with no codes whatsoever before getting it retuned. I should have just left it alone
I gained 2 whp though, hehe...from 196.0 to 198.2 whp and 132 torque.
I'm going to replace my current wire harness in the meantime and see how it goes...I figure if I convert to obd1 now and there are wiring issues, it will probably ground itself out too. But I will definitely ditch the pr3 in the future. thanks
not into drag racing...but I plan on taking my car to the track soon, just to find out. I expect mid to low 12's with a good pair of slicks and of course good driving.
Only one problem came up with my own stage 2 PR3 Hondata. CYP sensor CEL. Turned out to be a basd wiring.. Solved the problem when we replaced the engine with B20VTEC from a B16. Bad connection from the connectors it seemed.
ic...hopefully, the new harness that I ordered arrive soon so I can replace this piece of crap and finally get on with tuning. If I can only make it to 200 whp then I can stop for awhile
NOT! I'm almost there though, then what's next, hehe...
Kotsemoto,
I was wondering if you have had any idle/warm start-up problems with your PR3/Stage 2B set-up.
I am using a PR3/Stage 2B in my b18c1 turbo '89 CRX.
If you have had any problems, please let me know how you fixed it.
Thanks.
Thanks.
