b20b into del sol, hose problem
right there i have that thick hose that loops right around into the block
directly between the two connections for that there is a slightly smaller hose, its quite dirty in that pic.
where does it connect too? ive posted on a couple other boards and all i get is people arguing about what it is
please someone help me out
in that pic its near the bottom with a bolt in it
it is a coolant hose
it is a skunk2 intake manifold for an LS teg
it is a jdm b20b from a 99 orthia
if your not sure but have an idea or if you know what it is, feel free to post or email me or im me on XLerate93
thanks
Craig G
That looks like a skunk2 manifold to me. If it is, and we're talking about the same hose, you just need to block it off. I got a skunk2 mani so I know, but you'll need to point out exactly which hose for me to be sure.
yes finally someone with a semi-helpful response!!!
ive been thinking about blocking it off, but i wasnt sure
it connects right where the thicker hose does (the one that loops right around)
its hard to explain but hopefully you have an idea
or better yet, can you explain which hose your plugged off?
thx, Craig
thx, Craig
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek »</TD></TR><TR><TD CLASS="quote">I have a skunk 2 mani on a b20 and you need to block off that hose. I just used a screw slightly larger than the inside diameter of the hose. No leaks!</TD></TR></TABLE>
Exactly what I did. Good luck!
Curlybandit
Jul 22, 2018 06:42 AM
InTheZoneAC
Nov 15, 2012 03:44 PM
andybmuzik
10
Jan 24, 2011 08:09 AM
