How often U tune up your car ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4genaccordfreak »</TD></TR><TR><TD CLASS="quote">change the filter... this time spend the extra cash on a k&n filter which is washable and reusable.. the stock aem filters are not..</TD></TR></TABLE>
stock AEM filters ARE reusable. i've had 3 different AEM filter, and ive cleaned and reoiled all of them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StimpyBoy »</TD></TR><TR><TD CLASS="quote">You'll have to be more specific when you say "tune" your car.
Valve lash adjustment? Timing check? What?</TD></TR></TABLE>
I dunno, wut kind of tune up do u guys usually do when your car hit 90 K miles
any suggestion will be good
thx
thx
at 90K you should be doing
oil change
valve adjustment
coolant change
trans fluid change
brake line flush along with the clutch if equipped
power steering system flush
timing belt
water pump
valve cover gasket and tube seals
balance shaft seal & belt
cam seal /crank seal
spark plugs
cap & rotor
fuel filter
that is what a 90 k service should include
also check brakes, shocks, all bushings tires
oil change
valve adjustment
coolant change
trans fluid change
timing belt
water pump
spark plugs
cap & rotor
fuel filter
