engine won't pass 3000 rpm
Old Aug 13, 2003 | 12:24 PM
streetdreams420's Avatar
Default engine won't pass 3000 rpm
I just finished my dx intake swap to mpfi and when I give it gas the car will go to 3 grand then surge it will not go passed 3200 like it's at its rev limit what is causing this can anyone help
p.s. I have been told that its my distributor but don't get why it's doing it only when I get to 3 grand it runs fine under 3 grand then acts like its at its rev limit
Old Aug 13, 2003 | 12:25 PM
xvracing's Avatar
Default Re: engine won't pass 3000 rpm (streetdreams420)
It sounds like your car is in "Safe mode", Are you getting are codes?
Old Aug 13, 2003 | 12:30 PM
civickiller's Avatar
Default Re: engine won't pass 3000 rpm (xvracing)
yeah its your ecu in safe mode, tell us what codes your getting. probably like a crank angle sensor thing
Old Aug 13, 2003 | 12:32 PM
slowpokesi's Avatar
Default Re: engine won't pass 3000 rpm (civickiller)
something is wrong with your crank angle sensor, did you switch the 2 wires on the distributor?
Old Aug 13, 2003 | 12:34 PM
Default Re: engine won't pass 3000 rpm (slowpokesi)
I just went and checked it i'm getting codes 4 and 9 and yes I did switch all the wires and checked them severel times now
Old Aug 13, 2003 | 12:36 PM
yup code 4 and 9 are your crank angle sensor. check your wires again more carefully
Old Aug 13, 2003 | 12:38 PM
the crank angle sensor wires go to the dizzy right if so I have checked them
Old Aug 13, 2003 | 12:41 PM
slowpokesi's Avatar
Well instead of checking them how bout you change them around,
the crank angle sensor is inside your distributor, its either not wired properly or the distributor is trash
Old Aug 13, 2003 | 12:43 PM
the middle 2 wires should be a white next to an orange and there should be a 3rd white wire
then on the bottom with the 3rd piece ont he right side there should be a white/blue and a orange/blue. both colors there be right up and down from each other
it should look like this witht eh wires in the connector
b/y b/g
wht ong white
w/b o/b
Old Aug 13, 2003 | 01:44 PM
ninjaMONKEY
Guest
Posts: n/a
when i was still obd-0 i had to switch the b/y b/g wires around. That should fix code 4. Also check the link how to fix codes
Search is your friend!!!!
Old Aug 13, 2003 | 02:15 PM
wu tang's Avatar
Default Re: engine won't pass 3000 rpm (ninjaMONKEY)
hey, my car did that for awhile, and i figured out what it is, go down to your ecu, and make sure that b10 and b12 pins arnt lose. that was my prob.
Lead_moose
22
Jun 7, 2010 02:11 PM
pos94accord
Jan 25, 2009 05:29 PM
vtec93accord
Apr 4, 2008 05:24 PM
vtec93accord
Apr 4, 2008 04:01 PM
nayrone
Nov 1, 2004 12:09 PM
