Climate control Lights... 92 civic CX... I want it to light up
Old Aug 12, 2003 | 09:11 PM
xxh23fuzionxx's Avatar
Default Climate control Lights... 92 civic CX... I want it to light up
How can i make my climate control, etc. . . light up? which wires should i check and stuff... Errrrrrr..
Old Aug 12, 2003 | 09:36 PM
dantastic's Avatar
my climate control lights up from the factory...
Old Aug 12, 2003 | 11:13 PM
salbaje's Avatar
Default Re: Climate control Lights... 92 civic CX... I want it to light up (xxh23fuzionxx)
turn up the dimmer switch
Old Aug 12, 2003 | 11:15 PM
navin's Avatar
Default Re: Climate control Lights... 92 civic CX... I want it to light up (salbaje)
fuse box under dash ..?
Old Aug 13, 2003 | 12:04 AM
elwood's Avatar
I got it!.......turn your lights on?
No seriously more info would be nice. What exactly is the problem?
What dosent light up? Is it climate control, or all of your interior
lights that are not comming on?
Old Aug 13, 2003 | 04:17 AM
white99gsr's Avatar
Default Re: Climate control Lights... 92 civic CX... I want it to light up (d15dude)
hmmm....i have the same issue in my 92 cx. all of the climate control lights worked fine until i added the eg9 gauge cluster, now the climate control lights dont work. anyone know how to fix it?
Old Aug 13, 2003 | 10:38 AM
as in i turb on the lights, It doesnt light up, and same with my Gauge cluster. All fuses are ok.. I just need to know which wire behind the climate control is the Light wire. i dont have a dimmer.. is that a big problem? Because my friends car has a dimmer and everything works fine, except the fact that the climate control in his car doesnt light up too... So if i can tap in a wire to the climate control, which wire should i look at?
Old Aug 13, 2003 | 02:45 PM
elwood's Avatar
If you are running a US underdash harness that came with
a dimmer switch then you will need it for the climate control
to light up. Or if you wanted to be cool and jump the wires
you could take it out. The dimmer switch is like a light switch
and when you take it out the lights turn off.
Old Aug 13, 2003 | 04:23 PM
realblag's Avatar
take it out and check the bulbs................
Old Aug 13, 2003 | 04:53 PM
dantastic's Avatar
my dimmer sucks and it makes my dash lights go out every now and then. im just gonna jump the swtich when im not lazy. i dont drive at night that much
94preludeguy
10
May 18, 2014 10:03 AM
bonkerzz
21
Nov 6, 2011 10:14 AM
tousaephanh
Oct 21, 2008 11:53 AM
B_Something
May 24, 2004 09:06 AM
