vtec
What kind of question is that?
The only thing that would be better about the vtec engine would be fuel consumption.
The non-vtec would be better, theoretically, of course. Because it's power range would span the entire rpm scale, instead of just from 4500 rpm (or whatever the f&^k it is).
Just my thoughts. I'm sure someone else will chime in saying that vtec would be better because it makes a cool sound.
:rolls eyes:
:rolls eyes:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinaACCORD »</TD></TR><TR><TD CLASS="quote">What kind of question is that?
you think a 2.2l with no variable valve timing is going to make more power down low than one with it?
there would be/is no difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M »</TD></TR><TR><TD CLASS="quote">
there would be/is no difference </TD></TR></TABLE>
i would assume that since you had vtec the lo and hi cam profiles would allow to have better power throughout the rpm range. with a non vtec the cam profile there is a compromise, with vtec you can be more aggressive. you may make the same peak power, but the area under the curve should be better.
Well, nevermind. Now that I've re-read and thought about the original question, it doesn't matter.
The question is too broad.
And, not to be rude, but who the hell cares? They're both gonna be slow.
87shytwhip
17
May 1, 2006 10:40 AM
