vtec
Old Aug 12, 2003 | 07:36 PM
david90's Avatar
Default vtec
assume everything else is the same such as weight, trans, is a 140 HP vtec better than a 140 HP non-vtec?
Old Aug 13, 2003 | 06:27 AM
carolinaACCORD's Avatar
Default Re: vtec (david90)
What kind of question is that?
The only thing that would be better about the vtec engine would be fuel consumption.
The non-vtec would be better, theoretically, of course. Because it's power range would span the entire rpm scale, instead of just from 4500 rpm (or whatever the f&^k it is).
Just my thoughts. I'm sure someone else will chime in saying that vtec would be better because it makes a cool sound. :rolls eyes:
Old Aug 13, 2003 | 06:30 AM
urbanlegend21's Avatar
New User
Default Re: vtec (carolinaACCORD)
you need to be more specific.................................
What VTEC engine and which non-VTEC engine?
Old Aug 13, 2003 | 08:17 AM
miege44's Avatar
Default Re: vtec (urbanlegend21)
theoretically, what would be better
Old Aug 13, 2003 | 09:50 AM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinaACCORD &raquo;</TD></TR><TR><TD CLASS="quote">What kind of question is that?
you think a 2.2l with no variable valve timing is going to make more power down low than one with it?
there would be/is no difference
Old Aug 13, 2003 | 09:58 AM
KGAccord's Avatar
Default Re: vtec (Nick M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">
there would be/is no difference </TD></TR></TABLE>
i would assume that since you had vtec the lo and hi cam profiles would allow to have better power throughout the rpm range. with a non vtec the cam profile there is a compromise, with vtec you can be more aggressive. you may make the same peak power, but the area under the curve should be better.
Old Aug 13, 2003 | 11:10 AM
Default Re: vtec (KGAccord)
Well, nevermind. Now that I've re-read and thought about the original question, it doesn't matter.
The question is too broad.
And, not to be rude, but who the hell cares? They're both gonna be slow.
mehheh1029
Jun 12, 2006 04:36 PM
87shytwhip
17
May 1, 2006 10:40 AM
lubmyinteg
Honda S2000
Feb 3, 2006 12:56 PM
Tarlacon
Apr 2, 2005 07:30 PM
HECDWS
Dec 25, 2004 10:26 AM
