Header for 5th Gen
it's actually the pattern of the exhaust ports on the head that is the problem. on the VTEC, the #2 and #3 cylinders are closer together. whereas the non-VTEC has all 4 spaced equally. (or do i have that backwards guys?)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">it's actually the pattern of the exhaust ports on the head that is the problem. on the VTEC, the #2 and #3 cylinders are closer together. whereas the non-VTEC has all 4 spaced equally. (or do i have that backwards guys?)</TD></TR></TABLE>
The port patterns are the exact same. The only difference is the vtec manifold is a 4-2-1 design with the o2 sensor on the secondary pipe. The non-vtec manifold is a 4-1 design with the o2 sensor on the primary section.
ah, okay. my bad.
then why are there always 2 different part numbers for the EX vs. the LX/SE?
and is it the same header for the 90-97 since it's still the F22 block, just in different variations?
then why are there always 2 different part numbers for the EX vs. the LX/SE? and is it the same header for the 90-97 since it's still the F22 block, just in different variations?
Kavehman
Feb 23, 2004 08:47 PM
ludevtec93
Oct 29, 2001 04:45 PM
no offense no harm intended just my two cents
