problems with a vx..
Old Aug 12, 2003 | 04:37 PM
HellbillY's Avatar
Default problems with a vx..
i have a 1992 vx hatch. its all stock except for rims and i hate the ones i have. any ways i was wondering what would make my car kinda hesitate under 2500 and not do it above 3000 rpms. i put fuel cleaner in it and i was wondering if the fuel filter may be clogged. the stock motor has 153xxx miles on it. i just need some opions and i also have no clue hwere the filter is. also does anyone know the overall diameter of the stock vx wheels. i have theses stupid 17s and i think my speedo is way off. at like 3500 rpm it only says im going 70-75. my wifes ex is at close to 80 or better at that rpm in fifth....any help would be cool...
Old Aug 12, 2003 | 04:56 PM
greatbiggiants's Avatar
Default Re: problems with a vx.. (HellbillY)
my 92 vx did the same thing. i want to know
Old Aug 12, 2003 | 05:14 PM
BauleyCivic's Avatar
Risky Business
Default Re: problems with a vx.. (greatbiggiants)
my 92 LX is 75 MPH at 3,000 RPM and your tranny is a lot longer...so the numbers dont sound THAT much off...follow a friend and do the same speed, and see how far off you are
Old Aug 12, 2003 | 05:17 PM
neilff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HellbillY &raquo;</TD></TR><TR><TD CLASS="quote">i have a 1992 vx hatch. its all stock except for rims and i hate the ones i have. any ways i was wondering what would make my car kinda hesitate under 2500 and not do it above 3000 rpms. i put fuel cleaner in it and i was wondering if the fuel filter may be clogged. the stock motor has 153xxx miles on it. i just need some opions and i also have no clue hwere the filter is. also does anyone know the overall diameter of the stock vx wheels. i have theses stupid 17s and i think my speedo is way off. at like 3500 rpm it only says im going 70-75. my wifes ex is at close to 80 or better at that rpm in fifth....any help would be cool...</TD></TR></TABLE>
sounds like a vtec-e problem
vtec-e engages over 2500 / 3000 rpm if im correct, and when it is not in vtec, the motor only uses 12 valves instead of 16
Old Aug 12, 2003 | 05:34 PM
Ass_Clown's Avatar
Default Re: problems with a vx.. (neilff)
my vx does the same thing hesitates around 2500-3000 rpm. It does it like right when i let of the gas and go back on and ****. Happens at all speeds though.
Old Aug 12, 2003 | 05:36 PM
HellbillY's Avatar
no i have an ex tranny in mine...i forgot to metion that i had to swap them..i still think my speedo is off. also i can hear my vtech switch over and it is closer to 4000. i know i have a vx moto. i looked on the block. so i dont know...
Old Aug 12, 2003 | 05:38 PM
Ass_Clown's Avatar
I have 97 ex tranny too
Old Aug 12, 2003 | 06:42 PM
Combustion Contraption's Avatar
your vtec does not switch on @ 4000 rpm. it switches on at 2200 if you have the stock motor/ecu.
Old Aug 12, 2003 | 08:05 PM
SOUNDEFFECTS's Avatar
Default Re: (LsVtec92Hatch)
My vx does the same little stupid hestitation...its just the motor. About your speed, its right. You have some stupid long gears.
Old Aug 12, 2003 | 08:16 PM
mooseknuckle's Avatar
Default Re: (SOUNDEFFECTS)
all this hesitiation means.... b-series
1zach4
31
Feb 9, 2007 06:28 AM
10 psi
Dec 13, 2004 04:31 PM
4speed
Nov 29, 2003 10:01 AM
Aaron Taylor
12
Apr 30, 2003 05:38 AM
FASTEG
Mar 20, 2003 07:36 AM
