what hp can i expect form this turbo?
Old Aug 12, 2003 | 03:36 PM
civictypenos's Avatar
Default what hp can i expect form this turbo?
fully built b18c1,standalone,15 psi
t3/to4e
57 trim
50 a/r
my goal is 450hp
is it obtainable with this turbo?
Old Aug 12, 2003 | 05:42 PM
Default Re: what hp can i expect form this turbo? (civictypenos)
Old Aug 12, 2003 | 05:49 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I would adive a bigger A/R with a stage 3 wheel. Maybe sc34 57trim-.63a/r. That can get you your goal. I would say 380ish at 15psi. But what compression pistons do you have? If there 10.1 i would give it 400ish depending on how the tuner tunes aggresive or conservative. Actually get bigger than that and you can make some killer Hp. IM me.
Old Aug 12, 2003 | 06:08 PM
-iLLuZioN-B18C1's Avatar
whats your CR?
Old Aug 13, 2003 | 04:39 AM
this is all in the plans,the plans are to build the engine and get 450 hp,im trying to do alot of research into what exactly i want.i got a good deal on a t3/t04e,so im wanting to know if its going to get me where i wanna be.the motor is not built yet,so i can choose what ever compression i want.this project is being built from the ground up.
Old Aug 16, 2003 | 11:29 AM
my compression is still up in the air,i can do whatever,im going to use a bigger bore as well,sleeved also.
jdmcivic1999
Aug 19, 2005 06:35 PM
ucantcatchmefoo
Feb 24, 2004 09:18 PM
igotyofire
Jun 30, 2003 12:34 AM
yisoulja
May 25, 2003 12:22 PM
*Boostwerks*
Jun 1, 2002 01:24 PM
