help with no grip bolt *oil pan*
Old Aug 11, 2003 | 09:14 PM
Accord98's Avatar
Default help with no grip bolt *oil pan*
yes i know, now i can't change my oil...
what do u suggest?...take it to a shop?..
oil changing place?...weld shop to another bolt welded on top of it and screw it out?...help would be nice...
thanx
Old Aug 11, 2003 | 10:00 PM
david90's Avatar
use a vise or a plier to turn it
Old Aug 11, 2003 | 10:24 PM
Accord98's Avatar
Default Re: (david90)
i mean like...its DEAD tight..
i over torque'd it..
Old Aug 11, 2003 | 10:47 PM
Stripped Honda's Avatar
99-0104
take it to juffy lube i am sure they know how to take it off sence i have heard many horror storied from them ....
Old Aug 12, 2003 | 02:13 AM
D114's Avatar
Default Re: (Stripped Honda)
you could always get a new oil pan. ask the dudes at the junkyard for one... and install that when you change the oil.
Old Aug 12, 2003 | 05:10 AM
Accord98's Avatar
vise sounds good...i bought a new drain bolt, $1.67
Old Aug 12, 2003 | 05:23 AM
Accord98's Avatar
does any1 know the size of the bolt?..
i'm plannin on getting one of those fram-sure drain, so i won't have to mess wit the bolt ever again
Old Aug 12, 2003 | 05:54 AM
iakona's Avatar
14mm.
Old Aug 12, 2003 | 06:22 AM
TypeSH's Avatar
Default Re: (iakona)
believe its either M12x1.25.... but double check.
I know M10 bolts have a 14mm head, so thinking M12 should correspond to the 17mm head. Pitch fairly certain cuz my friend bought a bolt at autozone (think he got 1.5) but it wanst right and got a smaller pitch that fit.
Old Aug 12, 2003 | 06:42 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
i can agree with 14mm...and also the vice should work...but you can also "torch" it and then it'll be easier to turn with a vice
Old Aug 12, 2003 | 08:37 AM
iakona's Avatar
yep, just make sure you don't have an oil leak and blow yourself to smithereens!!
Old Aug 12, 2003 | 10:31 AM
Accord98's Avatar
thanx guys/girls
Old Aug 12, 2003 | 11:41 AM
david90's Avatar
try turning it clockwise a little then counterclockwise.
jdm27ef
Mar 24, 2010 08:35 AM
95TEG
Jul 7, 2004 05:53 AM
Blaze45
May 18, 2003 10:53 AM
ek_will
12
Feb 16, 2003 11:21 AM
h46it
Apr 7, 2002 05:22 PM
