timing advance jumper . . .
Old Aug 10, 2001 | 02:38 PM
rioninja's Avatar
Default timing advance jumper . . .
When setting the timing, i'm not sure about something:
I know your supposed to jump the clip under the dash so that the computer doesn't change the timing advance while your adjusting it. But when i rev the motor, the timing is still going all over the place. Isn't jumping the connector supposed to overide the automatic advance?
Old Aug 10, 2001 | 03:09 PM
J28S's Avatar
New User
Default Re: timing advance jumper . . . (RioNinja)
The timing will advance when the throttle position changes. You need to adjust the timing at idle after the electric fan cycles once with the jumper on the ECU.
Old Aug 10, 2001 | 07:18 PM
rioninja's Avatar
Default Re: timing advance jumper . . . (J28S)
Thanks for the info. i wasn't sure if it was still supposed to advance when i hit the throttle.
philosofy1
Feb 1, 2008 04:43 AM
mortificationrock
Jul 10, 2007 04:26 PM
kixcrx
Nov 10, 2006 10:33 AM
