Wiring the Check engine light to my P28 ECU Anyone?
Old Aug 11, 2003 | 02:21 AM
AgentJam's Avatar
Default Wiring the Check engine light to my P28 ECU Anyone?
Anyone know the exact connections i have to make from my dash to the ECU to make my check engine light work in my 88 CRX??? It's running a D16Y8 with a P28 ECU. I need to check the codes so i can get this puppy runnin!
Old Aug 11, 2003 | 03:00 AM
zCivic's Avatar
Default Re: Wiring the Check engine light to my P28 ECU Anyone? (AgentJam)
When I made mine. I was told I could use the same jumper to set my timing to check ECU codes. Try that. They said it depends on what directions used but its worth a shot at least. Should be under your hood on the driver side.
Old Aug 11, 2003 | 06:11 AM
sleeper4dr's Avatar
i believe you can run a wire from D14 to a switch and then ground the other side. grounding D14 should activate the CEL codes for a P28 but i need to check and verify this.
Old Aug 11, 2003 | 06:13 AM
Hondasaurs's Avatar
Default Re: Wiring the Check engine light to my P28 ECU Anyone? (sleeper4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper4dr &raquo;</TD></TR><TR><TD CLASS="quote">i believe you can run a wire from D14 to a switch and then ground the other side. grounding D14 should activate the CEL codes for a P28 but i need to check and verify this.</TD></TR></TABLE>
It's pin D4. But you are correct.
Old Aug 11, 2003 | 06:29 AM
sleeper4dr's Avatar
Default Re: Wiring the Check engine light to my P28 ECU Anyone? (Hondasaurs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondasaurs &raquo;</TD></TR><TR><TD CLASS="quote">
It's pin D4. But you are correct.</TD></TR></TABLE>
thanks
Old Aug 11, 2003 | 07:02 AM
AgentJam's Avatar
Sorry guys, I have that switch on my ECU hooked up to the Brown wire (D4 i believe ) and a black ground wire. I took out my IAT just to make sure that i would throw a code and the light never came on.
So, once i have that switch flicked and i am grounding out the D4 wire, i should push a code to my dash light right? but how do i make sure my ECU is hooked to the light on my dash? Sorry if this is a dumb question but i'm new to the import world...Thanks!
Old Aug 11, 2003 | 10:58 AM
AgentJam's Avatar
nobody?
Old Aug 11, 2003 | 01:39 PM
AgentJam's Avatar
last call, Please Help! THanks!
Old Aug 11, 2003 | 02:47 PM
AgentJam's Avatar
Default Dead ECU?
Alrighty, my last post was about trying to get my check engine light to even turn on (dead bulb) when the car wouldn't even start. Now i got the light to work however the light wont blink when i ground out the D4 wire like it should. I was doing some wiring under the hood and think i possible could have fried my ECU. All the connections are there, my turn signals, gauges etc. work and the car even turns over but it wont start. I don't think it's the fuel pump either. I have a P28 hooked up to a D16Y8 in my 88 CRX. How would i check if my ECU is fried? I opened her up and saw no visible damage. PLEASE HELP
manasel
Engine Management and Tuning
Feb 4, 2015 06:32 AM
Kangolbrand
Mar 13, 2006 10:01 PM
StRoKeD-B16bEj2
Nov 27, 2005 05:18 PM
Mr.Death
Jul 9, 2005 06:50 PM
